Haynes manual.. yay or nay? - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Honda Powersports Ontario TourismSportbikeTrackGear
Old 08-12-2007, 12:16 AM   #1 (permalink)
Favourite Bike: Shovelhead.
Emanthehorse's Avatar
Other Motorcycle: 1982 T140ES
Extra Motorcycle: 1971 Triumph TR6R Chop.
Having fun blasting around on the TBS, but I don't know how to check the oil, no idea what spark plugs to use, how to check the coolant lever etc. etc.
So is the Haynes a good deal (seems to be $33 on Amazon) or is the factory manual the way to go here???
Emanthehorse is offline   Reply With Quote
Old 08-12-2007, 12:44 AM   #2 (permalink)
Favourite Bike: '98 Thunderbird Sport
denny's Avatar
Other Motorcycle: '06 Husqvarna TE 610
Extra Motorcycle: '95 TBird - Project
Haynes is OK, Factory is OK too. Although both have a few errors.
I'd start with the Haynes and if you need some of the other info then get the factory one later.
Cheers,Denny
denny is offline   Reply With Quote
Old 08-12-2007, 10:16 PM   #3 (permalink)
Favourite Bike: '99 Legend Frankenbike
crosstie's Avatar
Other Motorcycle: Wife won't let me!
I don't have the factory, I live by my Haynes manual.
"Creag an Sgairbh"
'99 SpeedLegendRetroCafeFighter:
ZX12R USD Forks : Custom 3-1 exhaust : FactoryPro jet kit : Speed Triple cams : Pod filters : ZX9R shock : 5.5" rear wheel : Customized seat : FEK : SPA speedo/tacho : Pazzos
crosstie is offline   Reply With Quote
Old 08-14-2007, 12:16 AM   #4 (permalink)
Favourite Bike: 2003 Speed Triple
Other Motorcycle: 1999 Legend
One error I am aware of is Oil capacity. the Haynes manual lists it as 4 litres.
It is in fact 3.75 litres. Not sure if the factory one has the same error. (cause i'm too lazy to get it and look)
No quarter asked, none given
Gdsila is offline   Reply With Quote
Old 08-14-2007, 09:49 AM   #5 (permalink)
Hmm, I just got through reading this article.
Says four liters throughout.
http://www.webbikeworld.com/Motorcyc...oil/tbsoil.htm
Old 08-14-2007, 01:05 PM   #6 (permalink)
Favourite Bike: Thruxton
Yea!!!!!!!
davidc is offline   Reply With Quote
Old 08-14-2007, 01:31 PM   #7 (permalink)
Favourite Bike: 2002 Thunderbird 900
I concur with Gdsila - the oil capacity has definitely been 3.75 liters the six or so times I have changed the oil on this engine (A 1994 Trident and a 2002 Thunderbird).
Overfilling will cause oil to travel up into the air filter and be much trouble.
After you have about 3 liters in, fill it a bit and check the level, and then repeat this operation until the oil is half way up the site glass when the bike is vertical. If it fills before 3.75 liters the old oil was not all removed (see an old thread on this).
I typically have the 1/4 liter of oil left for the next change and I waste it by running it through the crankcase just to clean out any old oil left in it.
Rick
RickN is offline   Reply With Quote
Black frame and wheels on a TT, yay or nay? redl1nerpm Triumph SuperSports 18 08-30-2007 02:15 PM
Haynes manual Medic09 Sprint Forum 1 08-28-2007 05:24 AM
Haynes Manual TBirdVI Maintenance & Workshop Talk 2 03-08-2007 10:04 PM
Haynes Manual altlcrzy Twins Technical Talk 2 01-30-2007 04:13 PM
Sportbike Cans on a T-bird? Yay or Nay 00wabbit Hinckley Classic Triples 36 02-28-2005 04:53 PM
