Replacement indicator bracket? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 08-10-2007, 02:51 PM   #1 (permalink)
Hi guys need some help on my 1999 Thunderbird. Difficult to explain. But the triangular chrome bracket that bolts to the headlight and has the indicator bolted through the middle?? This also attaches to two threaded studs on the top chrome sleeve of the front forks. One of these studs has broken. This means that the headlight assembly and screen are not secured properly and move about slightly.
The fix is to change the chrome upper sleeve on the forks. Now I have never done anything to front forks before so I am a little worried.
It looks like a matter of taking the top yoke off. Is it as simple as it looks. That is undoing the top centre nut and the two top nuts of the forks? What happens when I do this? Do springs and things fly everywhere?
I have done most repairs to bikes over the years, but never played with the forks.
Is this best left to a dealer?
Help most appreciated
tomsdad
tomsdad is offline   Reply With Quote
Old 08-10-2007, 04:07 PM   #2 (permalink)
Slinky's Avatar
The easiest way to replace it is to remove the front wheel and fender. Then loosen the pinch bolts and drop the fork leg down.
Don't touch the fork top nuts, there is no need.
Slinky is online now   Reply With Quote
Indicator relay replacement Navy Boy Daytona Deliberations 6 12-04-2007 07:12 PM
Speedo Cable bracket replacement part for £2.50 BorgCymru Twins Technical Talk 5 09-16-2007 10:12 PM
Indicator help bgcntry72 Hinckley Classic Triples 1 08-16-2007 11:56 AM
sidestand & bracket replacement on a Trident djw T3 Sport / Touring Forum 1 06-19-2007 10:53 PM
Headlight Bracket Replacement jquattro Twins Technical Talk 2 12-29-2006 06:46 PM
