Use semi-synth or full synth. engine oll. The viscosity will depend on the ambient temps in your part of the world. 10/40 will cover most options, if you live in a particulary hot part of the world you may be better off with 15/50.
Use DOT4 brake fluid.
The best pads (IMO) are the originals. You can use EBC replacements, they are cheaper but they don't seem to last as long, so it's a false economy.
Stick with GG rated pads. Avoid HH rated pads, they will eat your discs.
