Oil Consumption - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comHonda Powersports SportbikeTrackGear
Old 08-01-2007, 05:21 AM   #1 (permalink)
NeilD's Avatar
Oil Consumption
had to top up 2001 TBS oil yesterday, about 200 ML took it back to just over halfway up the window.. thats over 3000 miles - normal???
its done just over 21000, no sign of any leaks or oily silencers/smoke, so guess its just 'breathing' it out somewhere??
Neil
NeilD is offline   Reply With Quote
Old 08-01-2007, 11:29 AM   #2 (permalink)
Favourite Bike: Whatever I'm riding....
Other Motorcycle: 07 Tiger ABS & 79 T140
Extra Motorcycle: 95 TB & 08 Ducati S4RS
200ml is just over half a can of soda - that really doesn't sound like much to me. But then my 95 TB has somewhere approaching 50K and I ride it fairly hard.
Thu/Friday - I rode 1200 miles on motorways at typical speeds of 75-85mph. The oil went from right at the top of the sightglass to a bit under the bottom of the sight glass - how much that is, I do not know 'cause I haven't topped it back up yet.
FYI - the oil breather tube runs from the left hand engine cover (the one that looks like an 8) up and into the airbox between the airfilter and the carbs (so it doesn't foul the filter). There is a second tube that runs down from the airbox to the rear suspension link which is intended to drain excess oil/petrol/water - it should have a stopper in it. Unstopper it and see how much comes out.
Chris
"Panniers can never hold everything you want, but they CAN hold everything you need."
parrycm is offline   Reply With Quote
Old 08-01-2007, 03:04 PM   #3 (permalink)
NeilD's Avatar
I saw the airbox breather tube mentioned a while back and checked mine then - it doesnt have a plug in it.. I guess its only there for 'enviromental' reasons so that you empty any oil in to an approved container, rather than venting to atmosphere?? I'm not too worried about the small amount of oil used, just curious as i'm used to older bikes wehere topping up is part of the routine!
Neil
Old 08-01-2007, 06:58 PM   #4 (permalink)
Well, it's also allowing unfiltered air to be sucked up into the carbs - not a lot obviously but I would say you should stopper it. Also, that way, it will alert you to excessive oil/petrol pooling in the airbox.
Chris
Old 08-01-2007, 07:22 PM   #5 (permalink)
Favourite Bike: Me Thunderbird of course
Other Motorcycle: Toyota Landcruiser
Extra Motorcycle: IT 490
The stopper may be way up the top of the tube, mine was the first time I checked it. I now have a small metal bung in it held in place with a zip tie. I remove it the night before I service the bike and let it drain. Sometimes it has a little oil in sometimes none. My bike has done 97,000klms, and the oil level drops a little sometimes( about 150-200mls) When it does the drain tube usually gives me a little oil back.
I believe there is no such thing as accidents. When I ride I must leave enough room for others stupid mistakes, added to that is enough room to make my own.
WoodsieIII is offline   Reply With Quote
Old 08-02-2007, 01:59 AM   #6 (permalink)
NeilD's Avatar
thanks, I'll check to see if the stopper has been pushed further up the tube, if not I'll fit one..
Neil
oil consumption dfelix Speed Triple Forum 55 08-24-2009 09:23 AM
Oil consumption Tigercat Tiger Chat 23 01-14-2007 12:16 PM
oil consumption davsato Sprint Forum 32 07-30-2006 06:21 AM
Oil Consumption rbw0471 Tiger Workshop (archive) 10 07-22-2005 07:09 PM
Oil consumption Pat69 Maintenance & Workshop Talk 9 11-12-2004 06:36 PM
