Speaking of Valves! - Triumph Forum: Triumph Rat Motorcycle Forums
Honda Powersports SportbikeTrackGearMotorcycle.comOntario Tourism
Old 08-01-2007, 04:02 AM   #1 (permalink)
Smile Speaking of Valves!
Hello everyone !I didnt get to my valve adjustment this last winter.I made the tool,(mines not real pretty),but then spring rolled around,and I wanted to ride.
NOW everything has fallen in place to go to The Sturgis Rally ,except the odometer on the 99 Tbird now reads13700.
My bike runs fantastic, but I,m scared here.Round trip from my place here in Ogden,Utah to Sturgis , South Dakota is approx.1200 miles.
I decided I better run this by you guys.
I,m not going to trash an engine .I,d rather catch Sturgis next year!
Thanks and I hope your all having a great safe summer on your triples!MAX
maxpwr is offline   Reply With Quote
Old 08-01-2007, 05:06 AM   #2 (permalink)
Favourite Bike: Me Thunderbird of course
Other Motorcycle: Toyota Landcruiser
Extra Motorcycle: IT 490
I would at least lift the valve cover and check them. At 20,000 klms mine required no adjustment. At 30,000 they needed one shim, at 50,000 3 shims, at 70,000 no adjustment and none since. I check em every ten. It now has 97,000 klms, and I will be replacing everything I can find to replace at 100,000klms.
I believe there is no such thing as accidents. When I ride I must leave enough room for others stupid mistakes, added to that is enough room to make my own.
WoodsieIII is offline   Reply With Quote
Old 08-01-2007, 12:14 PM   #3 (permalink)
Favourite Bike: 96 Bird
Other Motorcycle: 97 BMW R850R
Extra Motorcycle: 71 Bonnie
MAX......go to sturgis and enjoy, if you dont go now, you may never,,my birds odometer reads the same..my bike runs better now than it ever has.woodsie has a point, but if you dont get to it...dont let it stop you.another 1200 miles cant hurt (much)...just my 2 cents worth.......................tom
its not leaking oil!!...its marking its spot!!!
tnsen is offline   Reply With Quote
Old 08-01-2007, 12:35 PM   #4 (permalink)
Favourite Bike: Well, Duh!
MickMaguire's Avatar
That's really bad advice... if a valve is tight it could easily burn out in 1200 miles. Get the check done ASAP and certainly before along trip. At the very least check them to see how tight they might be before deciding. How the bike runs is no indication of whether this maintenance needs to be performed or not.
However, having said that - if your valves were checked at 6000 like they should have been then in theory you wouldn't need them to be checked again until 18,000 so you are well within the service interval. Triumph now recommends valaves be done at 6k then every 12k after that. The original recommendation used to be every 6k.
Mick...
Just remember; an awful lot of the free advice you will get on forums is worth exactly what you paid for it. There will always be somebody trying to convince you to do something really stupid, just because they did it or want to do it.
Old 08-02-2007, 02:12 AM   #5 (permalink)
Talking
Thanks Guys for your input!!
I,ll definetly tear into it , before it goes anywhere!I,ll probably pull the cover this weekend and see whats going on.Regards,MAX
Old 08-02-2007, 09:00 AM   #6 (permalink)
you right mitch...sometimes my "live for the moment" gets away from me..lol...better to be safe with a precious bird (they dont make em anymore)...anyway, about those shims...i read where you can use any valve shim from any jap bike ,that there universal? .. meaning i can waltz into the honda shop and pick some up? . do they come in a set? .. individually?? .. .002 or .004 i dont speaky metric too good.....tom
Old 08-02-2007, 08:40 PM   #7 (permalink)
Petrol's Avatar
Three hours to check them,three hours to know,three hours to peace of mind............lol,your choice m8
Petrol is offline   Reply With Quote
speaking of saddlebags... skeeterbarnes Club Cafe' 14 01-24-2008 06:14 PM
speaking of oils..... speedblastr Twins Technical Talk 11 05-18-2007 07:06 AM
Speaking of BMW... Silverado57 Biker Hang-Out 5 02-26-2007 04:07 PM
Speaking of Weather stevent Biker Hang-Out 2 02-06-2007 04:12 PM
Speaking of K&N Istallation...... GrendelPrime Speed Triple Forum 8 03-05-2005 09:36 AM
