BikeBandit
Old 07-18-2007   #1 (permalink)
Newbie
TBS silencers
Hi I wanted to remove my TOR's and put a standard set of silencers on for the MOT but they have the dreaded uncaptive captive nut problem, well at least the one bolt I tried to undo did.
Question is, is there much boogery needed to get them off, I would imagine the head of the bolt will need to be ground off to get them off the bracket and then the uncaptive nut will be needed to be welded to the silencer?
Will the one remaining bolt which is firmly holding be adequate to support the top silencer?
It was a waste of time anyway as the bike passed with the TOR's anyway.
Thanks
Snakehips is offline   Reply With Quote
Silencers Problem TBS 98 du_ratai Hinckley Classic Triples 6 09-22-2007 04:30 AM
TBS Silencers - Opinions needed Aaron Hinckley Classic Triples 22 10-26-2005 08:20 PM
do you have to rejet when switching to TBS silencers 00wabbit Hinckley Classic Triples 1 08-27-2004 06:04 PM
2003 TBS silencers fit 98 TBird 00wabbit Hinckley Classic Triples 0 08-23-2004 11:00 PM
TBS and Toga silencers eagle Hinckley Classic Triples 0 02-05-2004 08:52 AM
