Old 07-09-2007   #1 (permalink)
Favorite Bike: 2002 Triumph Thunderbird
TonyD's Avatar
The Triumph Service Manual specifies Mobil HP 222 (now called XHP 222, I think) grease for lubing the rear suspension of the T'Bird and Adventurer, whereas the Haynes Manual specifies molybdenum disulphide (moly) grease. So far as I can see, Mobil XHP 222 is a lithium thickened grease that doesn't contain moly (although they also produce 'XHP 222 Special' which does). As usual, the Mobil product isn't readily available locally.
Any views on the correct/best grease to use for this purpose? Is moly grease the way to go or would a multi-purpose lithium grease do just as well?
Tony
My Photos
TonyD is online now   Reply With Quote
Old 07-09-2007   #2 (permalink)
KD5QOQ's Avatar
molybdenum disulphide is for low speed, high pressure applications. So, yes that would be the choice.
Jimbo
Kroger Plus Member
99 Adventurer
05YZ450F
89 CR500
81CR250
KD5QOQ is offline   Reply With Quote
Old 07-09-2007   #3 (permalink)
Favorite Bike: Well, Duh!
MickMaguire's Avatar
Either will be fine - I use the Mobil XHP as recommended in the manual
Mick...
Old 07-09-2007   #4 (permalink)
TonyD's Avatar
Thanks, gents.
Tony
My Photos
Old 07-10-2007   #5 (permalink)
I happened to take mine apart this spring (can't remember why now) and found that even though I had lubed it 2x a year it was not fully greased. You may wish to take the linkage apart and confirm this. I had to clean up some rust, etc, as a result. Now I KNOW it is fully greased.
Yee-haaaaa!
Old 07-10-2007   #6 (permalink)
I use a product called roller-plane grease, it is very high in moly, and has excellent water resistant qualities. It is not branded, I got it from a mine site I was working at, they use it on the draglines. I have had no trouble with the rear linkage in almost 100,000klms.
I believe there is no such thing as accidents. When I ride I must leave enough room for others stupid mistakes, added to that is enough room to make my own.
WoodsieIII is offline   Reply With Quote
Rear Suspension Maintenance roadduster2 Sprint Forum 2 08-06-2007 09:23 AM
Rear Suspension SAMAL Sprint Forum 6 03-19-2007 07:36 AM
Rear Suspension Adjustment Limey Speed Triple Forum 24 09-29-2006 02:09 AM
Rear Suspension motiztab Hinckley Classic Triples 0 07-04-2005 06:56 PM
rear suspension JVS1670 Speed Triple Forum 2 02-18-2005 09:31 AM
