sprag replacement - Triumph Forum: Triumph Rat Motorcycle Forums
Old 06-16-2007, 05:11 PM   #1 (permalink)
rupert
Have a 95 Speed Triple, sprag clutch has gone. Anybody got any information/tips on replacing it. Photo's would be useful.
Can this be done with the engine in the frame? turning the bike upside down suspended from block and tackle. Any help with replacing this part would be much appreciated.
Thanks Rupert :hammer:
Old 06-17-2007, 09:19 AM   #2 (permalink)
robsmoto
A search for earlier threads should provide much info on the sprag replacement.
Here is a link from one of those threads that has a series of step-by-step photos. I printed these photos out and they were very useful to me when I replaced my sprag.
Sprag replacement photos
Note: I didn't take these photos - but many thanks to the fellow T-bird owner that did.
[ This message was edited by: robsmoto on 2007-06-17 08:29 ]
Old 06-17-2007, 09:28 AM   #3 (permalink)
rupert
Thanks robsmoto,
They look good photo's should help. Will have a good look at them before I start.
Old 06-17-2007, 05:30 PM   #4 (permalink)
Main Motorcycle: Whatever I'm riding....
Other Motorcycle: 07 Tiger ABS & 79 T140
Extra Motorcycle: 95 TB & 08 Ducati S4RS
Those are Stan's pics (member id sware) - he did his sprag around the same time I did mine.
I honestly can't think of any benefit from inverting the bike and I can think of lots of disadvantages including dropping fluids all over the bike - no matter how careful you are, there are some left in the engine and ancillaries. Not to mention the impracticality of inverting a 250Kg bike!
Dropping the engine is not that bad a deal - I did mine on my own using a bike stand and a bike jack under the engine. But you could do it without all that if you have a mate to help you.
Chris
"Panniers can never hold everything you want, but they CAN hold everything you need."
parrycm is offline   Reply With Quote
Old 06-18-2007, 05:25 PM   #5 (permalink)
robsmoto
I couldn't find the original post containing the link to the photos. If someone can post a link to that forum article it would be useful. In the original thread there were lists of the parts needed to complete the job.
Old 06-18-2007, 05:40 PM   #6 (permalink)
There are pictures here:
http://www.triumphrat.net/modules.ph...view_photo.php
and here:
and here:
http://stanware.digoxy.com/imageuplo.../gallery12.htm
Here is the paghe you are looking for with parts etc.
http://www.triumphrat.net/modules.ph...21170&forum=14
You don't really need to remove the clutch, water pump or rear sprocket.
[ This message was edited by: Crusader3020 on 2007-06-19 01:57 ]
escape reality at any cost, i say
Crusader3020 is offline   Reply With Quote
Old 07-29-2012, 07:51 AM   #7 (permalink)
Main Motorcycle: Thumper
Torch69's Avatar
Other Motorcycle: a quad buggy
Extra Motorcycle: one day
Starter Wire
Ok, I was told.. by who doesn't matter... that by changing the main starter wire the sprag issue is resolved. I put a #4 welding cable between the starter & relay(?). The old wire with white line..... was half yellow and very stiff on the starter end..as in half the damn thing was too hard to bend easy.
My TBird is at 9000 km...
So we shall see.
LIVE & LET RIDE
Torch69 is offline   Reply With Quote
Old 07-29-2012, 05:22 PM   #8 (permalink)
Main Motorcycle: '96 Adventurer
ArferBrick's Avatar
Other Motorcycle: Yamaha TDR 125
So we shall see.
That actually makes sense because they say that the problem is caused initially by the starter turning too slowly - ie too little current getting through.
ArferBrick is online now   Reply With Quote
Old 07-29-2012, 05:45 PM   #9 (permalink)
Main Motorcycle: '98 Thunderbird Sport
denny's Avatar
Other Motorcycle: '06 Husqvarna TE 610
Extra Motorcycle: '95 TBird - Project
Yes, that sounds like a good idea to me!
Cheers,Denny
denny is offline   Reply With Quote
Old 07-30-2012, 03:32 AM   #10 (permalink)
Main Motorcycle: 1999 T'Bird Sport
lovecuba's Avatar
Extra Motorcycle: 1977 T140
Not Quite!
So we shall see.
The sprag clutch in our machines is a pretty solid piece of gear, but it has a weak link and that is the small diameter spring that actually engages the clutch. This spring can lose tension and thus when the starter button is pressed a fearful clattering is heard, the spring will not hold the sprags onto the starters hub and they flop around. The spring loses tension over time (some do, some don't) or because of the engine misfiring when trying to start, or in some cases break.
The spring can be replaced, usually with one out of a suitable sized oil seal, if it is clear that the mechanical parts of the clutch are okay, and they usually are if the problem is taken immediate notice of.
The starter motor will only draw so much current and in my view the factory gauge wiring is more than sufficient for purpose.
In saying all that though, given the OP's bike is a 95', it may not have the later model stronger clutch, many of which were replaced under Triumph warranty.
lovecuba is online now   Reply With Quote
Sprag clutch carpelux Hinckley Classic Triples 1 08-23-2006 06:49 AM
Sprag clutch steptoe Maintenance & Workshop Talk 8 03-19-2006 04:43 PM
Sprag Clutch Help Please! tigerwilson Tiger Workshop (archive) 7 12-08-2005 04:52 PM
Starter Sprag Clutch replacement SWare Hinckley Classic Triples 0 02-28-2005 12:13 PM
sprag clutch motiztab Hinckley Classic Triples 0 04-04-2004 03:49 AM
