AdvanstarMotorcycleShowsBikeBanditTrident-Exhausts.comMotorcycle.com
ShopTriumph.com
Old 06-12-2007   #1 (permalink)
Hey all,
Does anyone have any experience with LED indicators/blinkers on their Triumph? I'm looking to replace the pitted chrome covered plastic original indicators on my TBS. I'd rather go with LED lighting as it seems to be a bit brighter but don't know if they'll work on T Birds.
Anyone install any in the past?
As normal, any help offered would be appreciated.
Cheers!
blackfly is offline   Reply With Quote
Old 06-13-2007   #2 (permalink)
I am about to install a set of LEDs on my adventurer, you must eaither install a new flasher unit (15$) or put in some kind of load in the circuit (resistors).
The stock flasher is made for incandecent bulbs, which require more power, and when LEDs are wired in, the flasher thinks the bulbs are burned out, and flasshes really fast. so to counter this, add a resistor, at each indicator, of buy a new flasher, (which is what I did). hope that helps some.
oldspice10 is offline   Reply With Quote
Old 06-13-2007   #3 (permalink)
Favorite Bike: 95 TB & 07 Tiger ABS
I'm also fitting LED's - the mini's offered by Shock Racing which I bought here at bikebandit
The following LED relay is available for $12.95 plus ship through superbrightleds.com and is compatible with the stock item - should be plug and play, I'll let you know.
CF13GL-02
http://superbrightleds.com/flashers.htm
In case you don't know... these aftermarket LED indicators are not DOT-approved - I don't know if there are any exceptions.
[ This message was edited by: parrycm on 2007-06-13 00:43 ]
Chris
"Panniers can never hold everything you want, but they CAN hold everything you need."
parrycm is offline   Reply With Quote
Old 06-13-2007   #4 (permalink)
Favorite Bike: 2002 Triumph Thunderbird,
Readyt's Avatar
Other Motorcycle: Cannondale Prophet (Bike)
Chris,
I'm considdering these as well as Kellerman's. When you get them , I'd like to know how well they light up?
Thanks
Ted
Readyt is offline   Reply With Quote
Old 06-13-2007   #5 (permalink)
Ted....
They're not really bright but acceptable - IMHO. I put a pic in my Workshop album - click under my sig. I'll add a couple more of how I fitted them when I have time.
One thing I noticed with the Shock Racing two-packs... the colour varied distinctly, one was more yellow and the other was more orange. Luckily, having bought two packs to do front and back - I was able to pair the yellow one from one pack with the yellow one from the other pack and put those on the front. The orange ones will go on the back.
Obviously, it would have only been noticeable when the hazards were on - which I hope would rarely happen! But I'm sufficiently anal that it mattered :-D
[ This message was edited by: parrycm on 2007-06-13 13:33 ]
Chris
LED indicators - Help! Navy Boy Daytona Deliberations 12 03-25-2008 09:58 PM
LED Indicators Silverstripes Tiger Mods & Bolt-Ons 0 04-01-2007 01:05 PM
Help !!! fitting LED indicators... markspeed4 Modifications & Workshop Talk 8 07-21-2006 06:13 PM
LED Indicators robnobrakes Speed Triple Forum 7 09-19-2005 11:24 PM
LED indicators Modifications & Workshop Talk 11 12-07-2004 09:20 AM
