Help! I can't get the spark plug out. - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 20 (permalink) Old 10-19-2004, 02:44 PM Thread Starter
Main Motorcycle: 2003 Thunderbird
KenT140D's Avatar
Extra Motorcycle: 2008 T100 Bonnie
I need to remove the spark plugs on my Legend, but I found that the 5/8" hex long reach spark plug spanner just seems to keep turning round as though its not engaging with the hex on the spark plug. I took the rubber grommet out of the spark plug spanner in case that was interfering with it, but still no good. I understand that the spark plugs are in fact the smaller size hex and not the "normal" size as found on my '79 Bonnie. I'm wondering now if there is yet another size of spark plug - is this the case, or is there some technique that I am not aware of? With the spark plugs being buried so deep into the cylinder head I can't see what the problem is. Anybody got any suggestions?
KenT140D is offline
post #2 of 20 (permalink) Old 10-19-2004, 02:44 PM Thread Starter
KenT140D's Avatar
KenT140D is offline
post #3 of 20 (permalink) Old 10-19-2004, 03:23 PM
Main Motorcycle: Whatever I'm riding....
Other Motorcycle: 07 Tiger ABS & 79 T140
Extra Motorcycle: 95 TB & 08 Ducati S4RS
I looked up the recommended NGK plug and it says that it is a 18mm hex. Click here for NGK.com info
In my experience, the best tool for removing the plugs is the one that came in the tool kit - do you have that?
Chris
"Panniers can never hold everything you want, but they CAN hold everything you need."
parrycm is offline
post #4 of 20 (permalink) Old 10-19-2004, 03:23 PM
Chris
parrycm is offline
post #5 of 20 (permalink) Old 10-19-2004, 05:36 PM
Chris is right,
just checked my old plugs and I am running with NGK DPR8EA-9. 18mm hex.
I bought the Triumph plug tool at great expense only to find its not much more than a box spanner!
motiztab is offline
post #6 of 20 (permalink) Old 10-19-2004, 05:36 PM
Chris is right,
motiztab is offline
post #7 of 20 (permalink) Old 10-19-2004, 05:55 PM Thread Starter
KenT140D's Avatar
Thanks Guys, No, I don't have the tool kit supplied plug spanner, which is why I am trying to use the standard plug spanners I already have. So so does that mean that in fact there are 3 different size hexagons for spark plugs? Both spark plug spanners I have in my tool kit are common standard sizes.
KenT140D is offline
post #8 of 20 (permalink) Old 10-19-2004, 05:55 PM Thread Starter
KenT140D's Avatar
KenT140D is offline
post #9 of 20 (permalink) Old 10-19-2004, 06:10 PM
tridentt150v's Avatar
I've got just about every plug spanner known to man [well four or five anyway], and the only one that works on the TBS is the factory supplied one.
Others are too wide, too thick, too short, too narrow, etc etc etc
I'd say a japper bike plug would work, but which one????
tridentt150v,
Great Southern Land.
tridentt150v is offline
post #10 of 20 (permalink) Old 10-19-2004, 06:10 PM
tridentt150v,
New Ignition Coil, Spark Plug Wires and Iridium Spark Plugs...better performance? brownbomber Air Cooled Twins Talk 15 10-27-2009 03:25 PM
Spark plug wires HD_Softy Air Cooled Twins Technical Talk 6 09-04-2007 10:22 PM
spark plug help nono54 Speed Triple Forum 0 08-11-2007 01:00 PM
Spark plug change? Alekker Triumph SuperSports 8 05-22-2007 08:20 AM
another spark plug???????? f1eric Speed Triple Forum 13 09-20-2006 07:38 AM
