Old 05-30-2007   #1 (permalink)
Favorite Bike: 2002 Triumph Thunderbird,
Readyt's Avatar
Other Motorcycle: Cannondale Prophet (Bike)
Help-I have an opportunity to get a Centre Stand off of a 96 T-Bird. I have an 2002 Bird and want to make sure it will fit.
I can't try it out because it's in another state. Any knowledge of the frame differences particularly with the stand fitting. Or will all T-Bird Centre stands fit each year?
Time sensitive on this response
Thanks
Ted :hammer:
[ This message was edited by: Readyt on 2007-05-30 22:13 ]
Readyt is offline   Reply With Quote
Old 05-31-2007   #2 (permalink)
TonyD's Avatar
I have only ever seen the one kit sold for Thunderbirds/Adventurers, whatever the year.
Tony
My Photos
TonyD is offline   Reply With Quote
Old 05-31-2007   #3 (permalink)
Favorite Bike: 1999 Triumph Thunderbird
Other Motorcycle: 1999 BMW R1200c
According to my old Triumph Accessories catalogs, the center stand is the same for all T-Birds, Part #A9950063. I just installed one on my '99 T-Bird
Buck
bbuckley is offline   Reply With Quote
Old 06-01-2007   #4 (permalink)
tridentt150v's Avatar
The only ones it doesn't fit is the late model TBS's, and that is only because of the exhaust pipe setup. Or thats my understanding.
Edit:I think the Legends have troubles because of their lower overall height as well. I beleive the stand works, but the bike is raised that much higher vis a vis more effort required to lift it.
[ This message was edited by: tridentt150v on 2007-05-31 23:27 ]
tridentt150v,
Great Southern Land.
tridentt150v is offline   Reply With Quote
Old 06-01-2007   #5 (permalink)
TonyD's Avatar
There is a separate centre stand for the Legend which is shorter than that for the T'Bird/Adventurer, as is the side stand.
Tony
My Photos
Old 06-01-2007   #6 (permalink)
Tony, yes you are correct, I forgot about that.
But I guess it still helps, don't buy a legend one for an TB or visa versa.
tridentt150v,
Old 06-01-2007   #7 (permalink)
Readyt's Avatar
Thank You
Ted
Old 06-01-2007   #8 (permalink)
Favorite Bike: '04 Thunderbird
Other Motorcycle: 1998 Honda CBR1100XX
My centre stand is in use on my '04 TBird and has been fitted previously to my '95 and '02 models. The only minor difference I noticed with current bike was that the brackets with the stand stop-lugs (parts 3 and 4 Here) which attach to the frame had to be bent outwards slightly to make sure the corresponding lugs on the stand itself lined up with them when placing the bike on the stand. Seems unlikely, but it may be that the drag link on the newer bikes is very slightly narrower? Either way, you should have no problem with a '96 stand on an '02 bike.
Jodel is offline   Reply With Quote
center stand or rear wheel stand? SlackCat Speed Triple Forum 16 05-08-2006 02:53 PM
Kick Stand vs. Center Stand Tooth Modifications & Workshop Talk 9 10-19-2005 09:02 AM
Center stand and/or Swingarm stand or jack rprockey Hinckley Classic Triples 3 08-17-2005 06:21 AM
Paddock stand vs. center stand questions Solace Sprint Forum 6 04-01-2004 09:31 PM
Center stand and side stand wanted Sprint Forum 1 01-21-2004 08:38 PM
