Anyway just wanted to know what oil to use in the legend front forks, what make etc and would it be worth changing to a differant grade of oil pro cons etc
My shop manual says 10W-20 fork oil for the Legend (TB, Adv) from VIN 43510 up.
If your problem is front-end dive on braking and soft handling, then perhaps you should consider replacing the stock fork springs with Progressive variable-rate springs. I've fitted them on my Adventurer and it made a HUGE improvement.
Jim
