Motorcycle.com
Old 04-21-2007   #1 (permalink)
Newbie
Have a problem on my 95 T'bird that's foxing everyone! A few days ago it started 1st time and then after about 20 secs just stopped dead. It restarted immediatly, then stopped again. The 3rd time I just got a click from the starter as if the battery was flat. I charged the battery and now it would turn over very slowly but not fast enough to start. So far i have replaced the battery, removed the starter and had it tested ok, cleaned main earth connection and connection to starter and tried to jump start it off my car. Despite all this it still turns over so slowly it will not start. I know about the spragg clutch problems on this model as I replaced one on my previous T'bird but that manifested as a banging noise when the starter was used and gave me plenty of notice before finally expiring! Any ideas I am desperate! :???:
bigjohn is offline   Reply With Quote
Old 04-21-2007   #2 (permalink)
Sounds like its grabbed a piston or nipped up on a bearing. I could be wrong too. I would pull the plugs out of it first and check the compression. If the starter is OK and theres plenty of power there has to be something internal making it "bind up"
I believe there is no such thing as accidents. When I ride I must leave enough room for others stupid mistakes, added to that is enough room to make my own.
WoodsieIII is offline   Reply With Quote
Old 04-21-2007   #3 (permalink)
jimmyj900's Avatar
Try shorting across the starter solenoid terminals with a heavy screwdriver. If the bike cranks to speed then the solenoid is the problem. (Be sure the rear wheel is off the ground when you try this.)
Otherwise, WoodiseIII may be on target.
I'd check for internal engine binding by removing the sparkplugs and the right forward cover on the engine to expose the end of the crankshaft.
Turn the nut on the end of the crank CLOCKWISE and with the sparkplugs removed, the engine should turn relatively freely.
You'll feel three distinct 'lobes' on each rotation -- progressively more force required then it eases up -- as the camshafts rotate against the lifters.
A 'scraping' or 'grinding' noise (or feel in your wrench hand) indicates something bad has happened.
Jim
CAUTION: This post may have been altered and critical safety information deleted without the permission or knowledge of the author.
thunderbird in help Brandy Modifications & Workshop Talk 1 11-11-2007 11:55 AM
Thunderbird Two-Up? SherpaT Hinckley Classic Triples 15 02-13-2007 04:40 PM
95 Thunderbird Thundrr Hinckley Classic Triples 7 02-12-2007 08:51 PM
will a thunderbird tank fit a thunderbird sport? aeycue Hinckley Classic Triples 1 06-24-2005 03:54 PM
00 or 01 Thunderbird Engineer Hinckley Classic Triples 28 03-07-2004 01:35 PM
