On 2004-09-22 19:58, 00wabbit wrote:
Great. Now I've got to go drill out my silencers. Did you rejet? Or did you just adjust the mixture screws?
I added the OFFICIAL off-raod pipes anfd a K&N filter element. I shimmed up my needles in the carbs using #4 alloy washers under the needle. This works really good and you can do it without removing the carbs from the bike.
I will do a proper jet job this winter.
:wink:
