Trident-Exhausts.comAdvanstarMotorcycleShowsMotorcycle.com
BikeBandit
Old 09-21-2004   #1 (permalink)
I took my 1999 Adventurer to the shop the other day and was told that the previous owner had installed aftermarket pipes without re-jetting the carbs. He told me that it would cause rough running.
Has anyone run after market pipes without the re-jet? What kind of symptoms did it exhibit?
I have a problem with what appears to be a miss in the engine under heavy acceleration at 3000 RPM or so. There is also some stalling intermittantly at other times. Does this mesh with the re-jet issue?
Jim
Dedmon is offline   Reply With Quote
Old 09-21-2004   #2 (permalink)
I have teh slashcuts on my '96 Adventurer and it runs beautifully without rejetting. I have read many problems from people rejetting incorrectly (or paying a shop to do it wrong) and have heard of no significant issues with the "off road" pipes without changing jets --- other than popping on deceleration which won't be eliminated by jets but can be reduced by richening the mixture a bit.
Your problems may be related to other issues -- perhaps the prior owner tried some different jets on their own?
HTH
Ken
Trumpets4Years is offline   Reply With Quote
Old 09-21-2004   #3 (permalink)
glgavin's Avatar
I have to agree. Over the years the only side effect from the off-roads has been an increase in popping on decel if you leave the stock carb settings in place.
I have an occasional miss under heavy acceleration but I think it's related to a rich condition. This condition occurred after having to have rust removed from the tank and the carbs rebuilt.
:-g
Gary
Oahu, Hawaii
glgavin is offline   Reply With Quote
Old 09-21-2004   #4 (permalink)
Thanks guys,
That info helped. I may be one of the poor owners with a paint problem in the tank. I will keep looking.
Jim
Old 09-21-2004   #5 (permalink)
jimmyj900's Avatar
Nope. It will run a bit leaner but not rough.
If your idle is rough and the carbs have been balanced and there are no other mods, it should idle smoothly.
Unless there's been bad re-jetting, that sounds more like an ignition coil issue.
My 2K Adventurer had a rough idle and occasional misfire at around 3,000 rpm. Dyno runs (after rejetting) showed no visible problems and I probably wouldn't have found the coil problem if it hadn't become intermittant.
Replacing the coils with Nology coils cured both problems.
FWIW, the hardest carburetor problem to find is electrical!
Jim
http://s279.photobucket.com/albums/k...0Head%20Stuff/
Bub pipes and jetting.... GeorgiaBoy Twins Technical Talk 1 10-08-2006 02:37 PM
'05 Thruxton Carb Jetting/Off-Road Mufflers kakay Club Cafe 12 01-07-2006 08:07 PM
Jetting ? for D & D pipes Mp350 Twins Talk 1 10-30-2005 12:00 PM
Jetting Suggestions Needed for Off-Road Pipes (TORs) evilfunkgenius Twins Talk 11 07-31-2005 01:44 AM
Jetting and off road pipes. Hinckley Classic Triples 4 03-31-2004 02:05 AM
