How do I know if the inlet rubbers are restricted? I don't see the dimples on them. I has aftermarket silencers on it and the guy I bought it from said the previous owner had those put on and the carbs tweaked during that process. Maybe the mods have been done already. How could I tell be looking?
Verify which carbs you have -- Mikuni or Keihin CVK. There have been a bunch of carb swaps and tuning for one brand will be a disaster for the other. On a '99 you should have the Keihin CVKs.
If there are no dimples in the sides of the carb rubbers (engine side) then you've got the unrestricted version. These were installed on all Keihin models and the restricted rubbers were used on the Mikuni models.
The only way to determine what has been done with the carbs is to remove and inspect them. The stock Keihins use #28 pilot jets and #98 main jets with the stock mixture screw setting at about 1 turn. The stock needle is not adjustable and stamped N3RF with no shims under the needle head.
With the stock (unmodified) air filter box the biggest main jet you should install is a #100 and the biggest pilot jet is a #40. Larger jets will make the carbs too rich for performance. Power drops faster with an overly-rich mixture than a lean one, so take it easy on the jet sizes.
If you don't want to tear the carbs down, get a dyno run with a printout of the air:fuel mixture versus torque/horsepower and post it here. I'll take a look and see what's going on.
Take a look in my photo album for jet locations on the Keihin carbs.
Jim
