I have been meaning to post a thread on this for a while. I have had three mystery oil leaks on the gearchange side over the years on T300 Triumph's.
In every case the leak was caused by the same alternator "O" ring seal failing. If the alternator "O" ring oil seal is nipped during assembly or splits through old age a trickle of oil runs out from the bottom of the alternator past the chain drive sprocket cover/water pump and onto the ground on the left hand side. If you dont know what the cause is its almost impossible to fathom out by inspection only.
This is what I did to sort the leak out:
1. Remove the Alternator finisher (cover). If there is fresh engine oil at the bottom you have probably got the failed "O" ring seal leak.
You can see some engine oil on the chrome chain drive cover here. You will need a 8mm long reach socket to remove the three finisher cover nuts and a long reach Torx T-40 to remove the three torx bolts holding the alternator in. Be carefull one of the Torx bolts has an earth strap connection.
Then hand pull the alternator out:
See the trickle of oil at the bottom. Take a look at the split alternator "O" ring seal:
And the seal removed from the alternator:
Heres the tools, they must be slim (1/4 in drive) and long reach:
The part number for the "O" ring is 3600100-T0301. I reckon I can replace one of these in less than half an hour given the tools. Im quite good at this procedure now.
Before people start laughing about Triumph's and oil leaks, I stress the failed component is a Japanese one !
