After replacing my handlebars and installing a shorter brake line, the master cylinder developed a leak. I will follow the advice here to fix.
The reason I am writing is with respect to the screws, they are pozidrive not your regular phillips. This could explain the problems with stripping the heads. The little dot on the screw head indicates pozidrive. Forgive me if I'm telling anyone how to suck eggs.
Brad
