Engine Breather - Triumph Forum: Triumph Rat Motorcycle Forums
Old 04-03-2007, 08:34 AM   #1 (permalink)
Favourite Bike: 1999 T'Bird Sport
lovecuba's Avatar
Other Motorcycle: 2001 Sprint ST
Extra Motorcycle: 1977 T140
Replaced left cover seal as per Hayne's instructions. Removed mandrel immediately prior to fitting then once cover is torqued up leave all for at least 15 min. Now, once again, airbox taking in excessive oil! Sump level correct, running Morris 10/40 semi synthetic API SF/SG. Seal cost $NZ75. Some are saying replace the spinner as new models have a metal bearing surface for the (next) new seal!!!!!!! Have a K & N filter fitted so do not want mineral oil contaminating it.
Anyone tried these stainless steel oil filters from Scot's? They seem to be the go as Triumph (NZ) rip us off here for genuine one's.
lovecuba is offline   Reply With Quote
Old 04-03-2007, 12:41 PM   #2 (permalink)
jimmyj900's Avatar
It may take a week or two for the oil in the filter box to drain out. You've also got a bunch of oil in the vent line from the engine that needs to clear.
Give the fix some time to work. :wink:
Jim
[ This message was edited by: jimmyj900 on 2007-04-03 10:42 ]
Old 04-03-2007, 06:07 PM   #3 (permalink)
lovecuba's Avatar
Hi Jim
all hoses and airbox cleaned of oil prior to fitting new seal. All okay for 350 miles then noticed oil leak from air box! Removed carbs. and split airbox. Same as before, excess oil!>
Regards
Murray.
Old 04-03-2007, 11:34 PM   #4 (permalink)
Favourite Bike: 1995 Thunderbird
SWare's Avatar
If you are still sucking oil past the seal, I'll bet you deformed it during reassembly. I had to try it a couple of times before I got it right. I found it handy to expand the opening in the seal a little more with my pinkie. Just be careful not to tear it and allow some extra time (an hour or more maybe) before starting the bike.
Stan
SWare is offline   Reply With Quote
Old 04-04-2007, 02:23 AM   #5 (permalink)
lovecuba's Avatar
Cheers Stan
was as careful as humanly possible when replacing cover. Point taken though, have kept mandrel so will take cover off, insert mandrel and inspect seal and seal bearing surface on oil flinger shaft once again. Great bike, but this breather system is to much! What was wrong with a simple rocker cover to air box system hose?
Regards
Murray.
Old 04-04-2007, 10:12 AM   #6 (permalink)
Favourite Bike: Well, Duh!
MickMaguire's Avatar
sometimes you need to replace the centrifugal breather assembly and not just the seal. I saw this on a legend once.
You should also take the air filter box off, dismantle it and clean / reoil the filter if you have been getting a lot up there.
Mick...
Just remember; an awful lot of the free advice you will get on forums is worth exactly what you paid for it. There will always be somebody trying to convince you to do something really stupid, just because they did it or want to do it.
Old 04-05-2007, 06:49 PM   #7 (permalink)
lovecuba's Avatar
Cheer's Mick
have ordered a new breather assembly and seal, so hear's hoping.
My Adventurer was imported from the States about August last year, I am told, from California. It is red and black and the previous owner was up with the play enough to fit a K&N, Triumph slash cut mufflers and re-jet the carbs. Very few of this model in New Zealand as they were not imported by Dealers. Has no emission gear fitted. Goes like a streak of weasel piss and frightens some Harley owners!
Engine number is 394DJ1112549. Would anyone recognise that? Like to contact the previous owner, he/she might be on this board?
Regards
Murray.
Breather Problems lovecuba Maintenance & Workshop Talk 0 10-25-2007 05:05 PM
tt600 breather rs_tt Triumph SuperSports 0 07-03-2007 10:31 PM
Engine Breather lovecuba Hinckley Classic Triples 1 04-23-2007 10:15 AM
Scrambler engine breather....... johnyC Twins Technical Talk 0 02-22-2007 01:24 PM
crankcase breather 6string Hinckley Classic Triples 4 06-22-2006 05:04 PM
