coolant on the ground - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Ontario TourismMotorcycle.comHonda Powersports
Old 03-31-2007, 02:20 PM   #1 (permalink)
Favourite Bike: '99 Legend
legend's Avatar
Hey guys,
Had my Legend warming up in the driveway for about 10 minutes when i noticed coolant pouring out of the over flow tube. I shut it down and checked the level in the reservoir tank when it was hot and then when it was cold. Both levels looked correct.
Did I leave it idling too long or could it be something else? It was only 45 degree air temperature and the temperature light or fan did not go on.
Any ideas would be welcome.
Thank you,
Mark
If it were easy, everybody would be doing it and we would all be out of a job!
legend is offline   Reply With Quote
Old 04-01-2007, 01:09 AM   #2 (permalink)
I had a similar problem last summer. Coolant level okay and no temperature extremes. It turned out to be a cracked plastic tee in the coolant tubing up under the gas tank. A couple dollars later all was good. Hope yours is as simple a fix.
John
LITTLEJOHN is offline   Reply With Quote
Old 04-01-2007, 09:21 AM   #3 (permalink)
legend's Avatar
John,
Thanks, I'll check that out. Did it leak out of the cracked tee only or did it discharge from the over flow tube too?
Thank you,
Mark
Old 04-01-2007, 09:53 PM   #4 (permalink)
Last summer the thermostat that brings on the fan on my Tbird went out. I rode around without knowing the fan was not coming on (only notice the thing when it IS running). I overflowed coolant. Dealer said that they never had to replace one of these before. Make sure that your fan is operational.
hyzer is offline   Reply With Quote
Old 04-01-2007, 10:28 PM   #5 (permalink)
Favourite Bike: Whatever I'm riding....
Other Motorcycle: 07 Tiger ABS & 79 T140
Extra Motorcycle: 95 TB & 08 Ducati S4RS
It's not unknown - My TB (and I think Slinky reported the same thing) does the same thing when topped to the full level.
Chris
"Panniers can never hold everything you want, but they CAN hold everything you need."
parrycm is offline   Reply With Quote
Old 04-03-2007, 11:14 PM   #6 (permalink)
legend's Avatar
I haven't added any coolant since I changed it last June. I rode it all summer into the fall without any incidence. (except the initial air bubbles)
It still has me worried.
Mark
Old 04-15-2007, 12:45 PM   #7 (permalink)
I had the same problem. It was at the dealers, and they were careless putting the tank back on, cracked the plastic elbow coming out of the overflow tank, so when coolant went between the radiator and the overflow, it would spit out the cracked elbow. I didn't see the crack until I followed the coolant trail and wiggled the tubing.
John
01Legend is offline   Reply With Quote
Coolant stains on coolant hose? moyster Speed Triple Forum 3 10-09-2007 12:02 PM
Ground issues SBTThruxton Club Cafe' 11 03-30-2007 11:10 AM
Brown coolant??? Coolant change?? Suncoast Sprint Forum 8 02-05-2007 12:51 PM
Flushing 01 coolant, no manual? coolant bubbles after use! speedtripleride Speed Triple Forum 1 05-21-2006 12:53 PM
Triple to the ground! drainbamage Speed Triple Forum 10 02-27-2006 01:04 PM
