fork springs - Triumph Forum: Triumph Rat Motorcycle Forums
Old 03-25-2007, 10:26 PM   #1 (permalink)
Cecfelix
hello, i'm new to triumph rat and i'm hoping some one will read this and help me out. i have a 95 thunderbird and the forks are soft, real soft, i cut some pvc pipe and put in the forks to stiffin them up. it helped, it no longer bottoms out but did not help much with the feel when i'm riding, i would like to upgrade the fork spring but have had little luck finding a upgrade for my bike and i'm not sure if thunderbird sport spring will fit or if there any better. please if you can help e mail me any info will be appreciated thanks felix
cecfelix@gmail.com
[ This message was edited by: Cecfelix on 2007-03-25 20:47 ]
Old 03-26-2007, 07:08 AM   #2 (permalink)
You can find springs from Race Tech. You can order those at any motorcycle dealer and they have different spring rates. They are linear and another part of the group will let you know where to find progressive springs.
In doubt, crank the throttle.
Saigon5 is offline   Reply With Quote
Old 03-26-2007, 11:07 AM   #3 (permalink)
jimmyj900's Avatar
Well, I'm the progressive-rate spring side of the group...
I installed Progressive Suspension 11-1144 front springs with 5-7/8" PVC spacers and 20W oil.
The airspace above the oil was set at 120mm with the inner tube vertical, fully extended and the spring installed.
That gave about 3/4" of preload and required almost exactly 1 pint of oil per tube.
Since the Adventurer doesn't have damping adjustments the 20W oil stiffened it up a bit.
That got rid of the dive wihout making the ride harsh and the entire installation was about $100 including springs, oil and a couple of feet of pvc pipe from the local hardware store.
Jim
Old 03-27-2007, 08:52 PM   #4 (permalink)
Favourite Bike: The one I'm on
Other Motorcycle: 2006 Sprint ST ABS
Extra Motorcycle: 2000 Thunderbird
Progressively wound fork springs can be had from:
http://www.davequinnmotorcycles.com/...webc/home.html
I've just received a set along with the rear shock for my bird. They come highly recommended and I can't wait to get them installed. I didn't want to refresh one end without the other so I got both for $501 - $375 for the shock and $126 for the front springs.
BTW, Dave Quinn is in Ct - maybe you'll save on shipping. Good luck!
Could you see me if I was standing on your hood kicking in your windshield?
upNorth is offline   Reply With Quote
fork springs motorcycleboy Club Cafe' 4 03-09-2007 03:15 AM
Anyone want to trade me their S4 fork springs for my TT600 springs? BombFactory Triumph SuperSports 10 02-11-2007 11:46 PM
S4 fork springs chitownG60 Triumph SuperSports 7 08-06-2006 11:38 AM
Fork Springs - What do I need? Tre900 Hinckley Classic Triples 6 06-17-2006 03:38 AM
Fork Springs ipg Tiger Workshop (archive) 6 03-03-2005 12:24 AM
