Okay, so that means I need to remove the heart shaped polished cover on the right hand side? Is it sealed from oil, or will all the oil run out? Will I need some new gasket if I remove the cover?
Looks more kidney shaped to me....
Get yourself a gasket before you open it up. The gasket may come away complete, but no sense waiting 2 weeks for a replacement if it breaks.
When you remove the cover, loosen the bolts in steps and in a star pattern or you may warp the cover! On the first twist of the wrench, only loosen the bolts about a quarter turn. That's enough to loosen the bolt but maintain tension on the cover.
On the second pass, another quarter turn. From that point on you're free to pull the bolts all the way out.
When you put the cover back on, tighten the bolts only to a light finger tight on the first pass. Use a star pattern and just use a socket and extension without the ratchet.
Go over the bolts again (star pattern) the same way and then torque to spec on the last pass.
Oh yeah, a smear of heavy grease on the engine side of the gasket will usually keep it from breaking next time you take the cover off.
If you remove the cover with the bike on the sidestand you won't get an oil spill.
Jim
[ This message was edited by: jimmyj900 on 2007-03-24 20:02 ]
