Headlight reflectors - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismMotorcycle.com Classifieds!New BonnevilleMotorcycle.com
Old 03-20-2007, 08:11 AM   #1 (permalink)
Gyprey
I had a headlight bulb blow on my Thunderbird Sport and when I went to fit a new one I discovered that one of the small nibs on the reflector that holds the bulb clip had broken. I telephoned my local dealer to order a new reflector only to be told that I had to order a complete glass rim reflector etc at a cost of £106. I rang Triumph direct to see if they could help but they said tough they could not supply a reflector on its own.
I don't need the rest. Does anyone know where I can get just a reflector. In the meantime I have used Araldite on the old one which seems to be holding. :
Old 03-20-2007, 03:30 PM   #2 (permalink)
Slinky's Avatar
Any car spares shop should be able to sell you one for a few quid. It's just a standard 7" H4 unit, as fitted to millions of cars and bikes.
Old 03-20-2007, 04:27 PM   #3 (permalink)
jimmyj900's Avatar
Like Slinky said, it's a standard item but be careful or you may fail your MOT with the wrong lens.
I bought a cheap replacement from JC Whitney and it's not marked as "DOT compliant" per federal law, but since there's no detailed mechanical inspection here in Texas it's not an issue. :wink:
Jim
[ This message was edited by: jimmyj900 on 2007-03-20 14:28 ]
Old 03-20-2007, 04:28 PM   #4 (permalink)
Favourite Bike: Hinckley Classics
vonbonds's Avatar
Upgrade to an Adjure Ice. I saw a pair on a Rocket III and the improvement was amazing to be honest over the stockers.
Adjure 7"
vonbonds is offline   Reply With Quote
Reflectors??? On or off........ AceT100 Twins Technical Talk 40 08-14-2007 11:24 PM
Removing reflectors Alyron619 Twins Technical Talk 7 06-10-2007 09:55 PM
Reflectors Wanted Berta Twins Technical Talk 5 11-16-2006 12:13 PM
removing reflectors ocman Twins Talk 9 04-11-2006 08:49 AM
Reflectors joeygloor Speed Triple Forum 9 08-12-2004 05:01 PM
