Jimmyj900, Could you expound on the tip over valve a little? Is it common to all Triumph's? I dropped my Trophy and it started initially but now I get nothing. It seems like there is no fuel getting to the carbs.
The tipover valve is located on a short stub of hose that comes off the left rear of the tank. It's a black plastic cylindrical device about 2-1/2" long and about 3/4" in diameter and the "big end" must point down. A long hose comes off the big end and runs down by the suspension so that any fuel overflow from the tank goes onto the road rather than through the carbs.
The tilt valve (unless tilted) functions both for fuel tank air venting and as part of the overflow system for the fuel tank. When installed and working properly it allows pressure and excess fuel venting from the tank -- like when you fill the tank and park the bike in the sun.
The tilt valve also provides considerable reverse airflow into the tank, so as you use fuel it can be replaced by air. If the valve stops working, it allows a vacuum to begin building in the tank and eventually the vacuum can prevent fuel from flowing.
Jim
