Suggestions for front forks replacement - Triumph Forum: Triumph Rat Motorcycle Forums
Old 03-18-2007, 09:00 PM   #1 (permalink)
Time to rebuild by "totalled" 2000 Legend. I may need to replace the front forks. Scot D. suggested a 43mm Showa. Is there a particular bike that a Showa fork is originally part of. Any suggestions folks?
Thanks, Eric
EricMichael is offline   Reply With Quote
Old 03-18-2007, 10:57 PM   #2 (permalink)
ZRX1100/1200, Any of the carbourated 1st gen Triumphs like Daytona 900/1200, Speed Triples, Tridents and Trophys.
2000 TBS Cafe Racer :: 2000 Frankenmille
TBSstunta is offline   Reply With Quote
Old 06-19-2007, 11:18 AM   #3 (permalink)
udroma
If one were to put forks from a ZRX1200 on to a Thunderbird, how would that change the riding position, rake and steering, etc and so on. Or doesn't that make a difference?
Thanks,
Udroma
Old 06-19-2007, 12:27 PM   #4 (permalink)
Favourite Bike: Well, Duh!
MickMaguire's Avatar
ZRX forks on a TBird:
It lowers the front a little but handling is fine. Rake and trail affected accordingly.
The biggest hurdle is that you would really have to change the entire front end (not just forks) in order for it to be a boilt on swap. You may need to re-shim the rear wheel in order to get correct alignment, but I may be wrong (I cant remeber if the front wheel offset was the same - I think it may have been).
[ This message was edited by: MickMaguire on 2007-06-19 10:27 ]
Mick...
Just remember; an awful lot of the free advice you will get on forums is worth exactly what you paid for it. There will always be somebody trying to convince you to do something really stupid, just because they did it or want to do it.
Old 06-19-2007, 02:55 PM   #5 (permalink)
udroma
Thanks for the info Mick. I'm really just dying for twin discs up front would you know of another way besides replacing the entire front end? Would it be easier to find a TBS front end?
Thanks,
Udroma
Old 06-19-2007, 03:44 PM   #6 (permalink)
TBS front end is a very easy swap if you could find one - they are rarer than hen's teeth - brakes wise they arent a patch on the zrx either.
Mick...
Old 06-19-2007, 05:00 PM   #7 (permalink)
A ZZR 1200 front end will also work. The fork slider is different than the ZRX unit I believe.
zs-cafe is offline   Reply With Quote
Suggestions for replacement headlights? taylo951 Speed Triple Forum 5 10-04-2007 01:56 AM
Suggestions for forks? never Speed Triple Forum 1 07-27-2007 07:38 AM
S4 replacement mirror suggestions? MercuryMan76 Triumph SuperSports 9 05-04-2007 11:09 AM
Seat Replacement Suggestions/Help Charro Twins Technical Talk 25 03-15-2007 11:31 AM
Replacement forks MadMark Triumph SuperSports 0 05-13-2005 05:07 PM
