Noob Questions - Triumph Forum: Triumph Rat Motorcycle Forums
Old 03-18-2007, 09:16 AM   #1 (permalink)
1. When adjusting the chain, should the bike be on the centerstand, rear wheel off the ground?
2. What's involved in replacing the rubber chain-wear block on the swing arm?
Ride On!
meinschaft is offline   Reply With Quote
Old 03-18-2007, 11:41 AM   #2 (permalink)
Favourite Bike: Whatever I'm riding....
Other Motorcycle: 07 Tiger ABS & 79 T140
Extra Motorcycle: 95 TB & 08 Ducati S4RS
I have always held the bike vertical with the rear wheel off the ground to measure and adjust the chain. Having said that, if it became necessary to adjust the chain on the road, I wouldn't have a problem doing it on the sidestand.
I seem to recall replacing the chain block is easy enough once the front sprocket cover and the chain is removed. Provided the bike is vertical I didn't need to drain the oil either.
Chris
"Panniers can never hold everything you want, but they CAN hold everything you need."
parrycm is offline   Reply With Quote
Just a couple noob daytona questions!! Flat6 Daytona Deliberations 6 04-21-2007 06:17 PM
More questions from a noob.. HELP! whodkne Speed Triple Forum 6 03-27-2007 06:18 PM
95 S3 noob questions Tracker Speed Triple Forum 23 09-28-2006 10:27 PM
NoOb questions ewolfkiel Daytona Deliberations 9 09-15-2006 11:25 AM
Noob in the forums,..with some questions Alipashe Daytona Deliberations 5 08-12-2006 04:32 AM
