oil leak hiding - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Old 03-17-2007, 12:19 PM   #1 (permalink)
I replaced my engine recently and after getting the new one on I found I had an oil leak @ the drain plug. I tried to tighten it, replace washer, then teflon tape. still dripped from the drain plug, THEN I found it. just to the side of the drain plug, recessed into a part of the oil pan is a small torx screw. the oil is leaking from there and dripping off the drain plug when it gets there.
My question is what does this small torx screw secure?
I tightened it up and the leak stopped but I don't know what might have been loose on the other end of this screw and it's bugging me to know. :???:
whats the coldest you rode?
TravelinManOhio is offline   Reply With Quote
Old 04-03-2007, 09:04 PM   #2 (permalink)
so many have read my first post but no one has an answer?...lol
stumped the experts I guess.
Is everyone that has an oil leak dripping from the drain plug checking that screw now to see if it is the same problem?
Old 04-03-2007, 11:58 PM   #3 (permalink)
Favourite Bike: Whatever I'm riding....
Other Motorcycle: 07 Tiger ABS & 79 T140
Extra Motorcycle: 95 TB & 08 Ducati S4RS
Sorry - I did read this and made a mental note to check the underside of my engine when I got home...... and promptly forgot.
I disembowelled my engine to replace the sprag clutch a couple of years back but it didn't ring a bell even when I read your question. But, inside the sump there is an oil collection tray - I think part of its purpose is to ensure that cr*p isn't returned to the oilways. That torx screw helps hold the tray to the sump.
If I can find my fiche, I can tell you the part name, but don't hold your breath. No picture of the sump but other pics of sexy engine internals are below my sig.
[ This message was edited by: parrycm on 2007-04-03 22:00 ]
Chris
"Panniers can never hold everything you want, but they CAN hold everything you need."
parrycm is offline   Reply With Quote
Old 04-08-2007, 12:05 PM   #4 (permalink)
thanks for the clue chris. I know I found the fiche on-line somewhere a couple of years ago but can't seem to locate it now.
Hiding in Hawaii mjtool Biker Hang-Out 15 08-16-2007 05:54 PM
Oil leak from oil cooler pipe? FlyBri Twins Technical Talk 3 06-21-2007 12:58 PM
Oil leak, right-side oil cover Rincewind Tiger Workshop (archive) 2 05-30-2007 11:36 PM
oil filter seal failure - oil leak / spray mlc Twins Technical Talk 7 05-25-2007 04:09 PM
Oil leak->Gasket/Oil change->won't start Hinckley Classic Triples 6 11-25-2004 09:43 AM
