BikeBandit
Old 09-09-2004   #1 (permalink)
Spooner's Avatar
Can the choice of spark plugs have effect on the performance of the bike?
I guess what I'm asking is....is there any specific brand of spark plugs I wanna get
if I want to get a little more power?
Excuse the newbie type questions.....but I'm afraid that's exactly what I am.....a newbie :-D
Best,
Spooner
S.P.O.O.N.E.R.
Huh?
Speedy MattHilda & Thunderasaki
Spooner is offline   Reply With Quote
Old 09-10-2004   #2 (permalink)
Hi Spooner
I don't think you can add power by changing plugs. The only time I noticed any significant difference in plugs was when I installed Bosch super 4's in my trusty old Mazda 626...I got a more even accelleration, and the engine seemed to run smoother. But hey, that was a CAR.
I've tried different plugs in my Saab too (also car), noticeable difference was a poorer performance. Won't run properly unless it got standard ngk's in there...
T'Weed
The future's so bright, I gotta wear shades
Tumbleweed is offline   Reply With Quote
Old 09-10-2004   #3 (permalink)
glgavin's Avatar
Triumph recommends two heat ranges for their bikes. Summer and Winter. Locally I found that the colder (summer) plug and our fuel were not as compatible as the hotter (winter) plug for my TBS. Haven't made a plug check/change in the Tiger yet.
Also locally, the brand choice of plugs for motorcycles seems to be very limited.
:-g
Gary
Oahu, Hawaii
glgavin is offline   Reply With Quote
Old 09-10-2004   #4 (permalink)
I don't know of any performance gain.. I did swap out for Splitfire plugs during my last tune up, but I also swapped in a K&N air filter and richened the idle mixture a bit as well. The engine does reve a little faster, but I attribute that more to the air filter than the spark plugs...
Dave Arnold
'04 Rocket III
'01 Trophy 1200 (wife's ride)
La Vernia, TX
tbsrider2000 is offline   Reply With Quote
Old 09-10-2004   #5 (permalink)
I also put a K&N air filter on my Legend and noticed a nice boost in hp. I have stuck with the NGK plugs they work fine . If you want a little more from your Hinckley Classic then a K&N is the way to go...
No quarter asked, none given
Gdsila is offline   Reply With Quote
Old 10-15-2004   #6 (permalink)
I recently changed from NGK DPR8EA-9 (standard)
to NGK Iridium DPR8EIX-9 (recommended upgrade) on both my bikes and noticed an improved pickup in the throttle response.Whether they will show any other improvements over the long term i don't know,however i am pleased so far. These plugs are more than double the price of standard, so you'll have to judge for yourself if you feel they're worth it. I DO!
Gerry is offline   Reply With Quote
Old 10-15-2004   #7 (permalink)
Administrator
Favorite Bike: '04 Thunderbird Sport
Wombat's Avatar
Other Motorcycle: I wish!
I particularly asked this question of the Triumph tech at my dealer and his response was that unless you are going to be riding around at full revs, the standard NGK plugs are fine. I rarely get above 5000rpm as most of my riding is commuting.
The only upgrade that he would consider as worthwhile is the use of Iridium plugs.
Bob
Click to see My Photo Album
Age is of no importance, unless you are a cheese.
Wombat is offline   Reply With Quote
Old 10-15-2004   #8 (permalink)
mecscc's Avatar
Hi, Spoonman
The answer is "no," BUT, if you change plug brands, pay more money, and BELIEVE it helps, then do it. Can't think of a cheaper way to feel better about your bike.
Bottom line is that if any spark plug type or brand were actually superior to any other we'd all be using that brand.
Take care,
Monte
Monte
"The Old Ohio Preacher Man"
Spark plugs? awegs955i Daytona Deliberations 8 05-23-2007 10:09 PM
New Ignition Coil, Spark Plug Wires and Iridium Spark Plugs...better performance? brownbomber Twins Talk 11 04-03-2007 04:14 PM
spark plugs schmark plugs DaleE Hinckley Classic Triples 6 10-25-2005 10:54 AM
Spark Plugs msparks Sprint Forum 6 01-21-2005 04:02 PM
Spark Plugs? Sprint Forum 9 11-19-2004 03:16 AM
