Shift lever stays down - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Motorcycle.com Classifieds!Motorcycle.comSportbikeTrackGear
Old 03-15-2007, 01:42 PM   #1 (permalink)
Hello,
i buy a 01 TB 3 weeks ago and its a great bike.
but now there is a problem insight.
When shifting down, the shift lever stays sometimes in lower position for 3-5 seconds, then he goes up so you can shift down again. This happens first time 3 days ago, but problem is increasing, so it happens more and more often. in addition the neutral lamp works only 2of 10 times since yesterday.
Any idea ?
thanks for help..................
Greetings from Germany
:hammer:
[ This message was edited by: dynam on 2007-03-15 12:07 ]
dynam is offline   Reply With Quote
Old 03-16-2007, 10:24 AM   #2 (permalink)
Favourite Bike: 2001 thunderbird
Chadillac's Avatar
Other Motorcycle: 1975 MR175 Elsinore
I had a shift lever problem once when the teeth stripped a little on the post. Not only did it stay down, it nearly fell off.
The little steel pin held it on.
I repositioned and retightened it, but it slipped again. The teeth on the post we're still good but they were stripped on the lever. I eventually JB Welded and tightened it up. May not have been the best fix, but it hasn't slipped since.
Chadillac is offline   Reply With Quote
Old 03-16-2007, 03:32 PM   #3 (permalink)
Favourite Bike: Well, Duh!
MickMaguire's Avatar
On 2007-03-15 11:42, dynam wrote:
Hello,
Any idea ?
:hammer:
Sounds like the detent rollers on the gear selector drum are misbehaving - maybe the spring has broken or come adrift from one. the only way you will really tell is to remove the oil pan and take a look (or have your dealer look for you).
Mick...
Just remember; an awful lot of the free advice you will get on forums is worth exactly what you paid for it. There will always be somebody trying to convince you to do something really stupid, just because they did it or want to do it.
Old 03-17-2007, 10:58 AM   #4 (permalink)
Favourite Bike: 1998 TBS
Other Motorcycle: sold it
Extra Motorcycle: sold it
Before you take anything apart, make sure it's not just bound up from road grime. If a little penetrating oil on the joints makes it better, maybe it just needs cleaning.
Thunderbum is offline   Reply With Quote
Old 03-17-2007, 01:28 PM   #5 (permalink)
there aint no joints to bind on a regular thunderbird - the shift lever is bolted to the input shaft unlike the thunderbird sport's gearshifter.
Mick...
Old 03-20-2007, 12:44 AM   #6 (permalink)
You may have a problem with the neutral switch binding on the selector drum. To check it, loosen the switch a couple of turns and try it. If it improves, take the switch off, add a washer or two to space it out, and tighten up
harryfotter is offline   Reply With Quote
Old 03-20-2007, 10:07 PM   #7 (permalink)
Uh, yeah, I knew that. I think. Could there be some stickyness on the seal whare the input shaft penetrates the gearbox? I always like to try the simple fixes first.
Old 03-21-2007, 08:13 PM   #8 (permalink)
Favourite Bike: 00' Legend TT
Eyun_G's Avatar
If the lever isn't stripped and it's something in the transmission, I would suggest changing the oil. Definitely use the factory recommended stuff and see if that helps. My Legend always shifts better on fresh oil.
Cooler than the other side of the pillow.....
Eyun_G is offline   Reply With Quote
Old 03-22-2007, 03:56 PM   #9 (permalink)
Thanks for help,
today i checked the neutral switch and he is dead, sometimes he worked next moment he doesn´t. new one is ordered also oil pan seal, so i can take oil pan off and have a look.
First i did is clean it all and give a little lubrication.
Today i could only try the lever without riding because of really bad weather (snow, all day long).
Bike British, fight for your rights.
( Hope my English isn't too bad )
Dirk
Need a shift lever 2bugeyez Speed Triple Forum 0 03-19-2007 10:53 PM
NEED 955i shift lever nyburner Daytona Deliberations 3 08-15-2006 12:46 AM
Shift lever laying around? tri650 Classic, Vintage & Veteran 3 08-08-2006 12:27 PM
Shift Lever Fitch Sprint Forum 1 06-06-2006 09:28 AM
shift lever- @!&$$&% Longshot92 Maintenance & Workshop Talk 5 11-11-2005 07:37 AM
