I don't want to start a war or anything, but, if you have NOT been using high test, say 93 octane, then don't start. All higher octane does is reduce the size of the window for combustion.
It IS necessary for engines with bikes with a high combustion ratio, which the Tbird engine does not have. But, in an engine designed to run on lower octane when you burn a higher octane gasoline all you are doing is causing minute misfires and incomplete combustion, and those, over time, build up carbon deposits on the top of the pistons.
The irony is, of course, that, given enough time, the carbon buildup will, itself, increase the combustion ratio, thereby making the use of high octane gas necessary. In other words, it is a self-fulfilling prophecy. If you use 93 octane long enough you will NEED 93 octane, and you will prove yourself right. Problem is that you didn't need it in the first place.
Now, it could well be that a 97 Tbird that has always used 93 octane gasoline will, in fact, need to use it. Either that, or you would have to take off the head and scrape the deposits off of the pistons. In that case, I too would buy the 93 octane gas instead of taking the engine apart to save a dime a gallon.
Monte
[ This message was edited by: mecscc on 2004-09-09 20:16 ]
