Rear Suspension Disassembly question - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!New BonnevilleSportbikeTrackGear
Old 03-13-2007, 06:55 PM   #1 (permalink)
Favourite Bike: 2000 Adventurer
Woody1911a1's Avatar
Other Motorcycle: 67 T100C
Extra Motorcycle: Buell Blast
hey guys , i want to play with ride height by trying different length links .
manual just says raise rear end . i don't have a center stand so i'll be lifting using heavy ratchet straps . i just don't want any suprises .
question , do i want the rear tire completely off the ground when i unbolt the links or weight almost copletely off but tire still on the ground ? sorry if my question is confusing . any input would be greatly appreciated
Woody1911a1 is offline   Reply With Quote
Old 03-13-2007, 07:39 PM   #2 (permalink)
Favourite Bike: 1995 Speed Triple
meanchuck's Avatar
Other Motorcycle: 2005 Rocket III
Extra Motorcycle: 1998 Thunderbird Sport
You can do it either way, once you take the nuts off the bolts you will have to pick up the wheel and suspension a little to remove the weight off the bolts and get them out. What I have done before is if you have a floor jack for a car, raise the bike up (with your straps) enough to fit the jack under the back tire and then you can move the suspension up and down with the jack when the linkages are removed and will free up your hands when installing/removing the links. The suspension doesn't weigh a lot but when you are crawling around on your garage floor it is no use to work any harder than you have to.
[ This message was edited by: meanchuck on 2007-03-13 17:40 ]
Expelled From Old School
meanchuck is offline   Reply With Quote
Old 03-13-2007, 08:05 PM   #3 (permalink)
thanx meanchuck , wasn't sure if i did it the wrong way i'd get a nasty SPROIIIIIING when i undid the bolts .
and now in thinking about it , i've seen many pics of bikes suspended from straps , but how the f do the get them down ? lol rachet straps only ratchet up not down . think i'll use my come-along instead .
Old 03-13-2007, 08:59 PM   #4 (permalink)
meanchuck's Avatar
$100 Craftsman cycle/atv jack works good for me
Rear Suspension Question Chi-TownRocket The Rocket Science Forum 4 08-10-2007 02:33 AM
Rear suspension question cracKness T3 Sport / Touring Forum 1 10-26-2006 12:03 AM
Rear suspension question....Please help... Brk4moose Twins Talk 6 07-18-2006 09:21 PM
Rear suspension question....Please help... Brk4moose Twins Technical Talk 1 07-17-2006 10:23 AM
SSSA disassembly question bridgestone175 Sprint Forum 7 08-19-2005 12:15 PM
