Motorcycle.comTrident-Exhausts.comAdvanstarMotorcycleShowsBikeBandit
Old 09-07-2004   #1 (permalink)
Why is it that my tbird starts to run a little rough when the gas gets low? At about 100 miles I notice a little rougher running. Is it because there is less gas in the tank and less pressure in the lines, or something floating in the gas?
00wabbit is offline   Reply With Quote
Old 09-07-2004   #2 (permalink)
Old 09-08-2004   #3 (permalink)
here is an anecdote that may prove useful :
A friend of mine changed carbs on his ducati 900 twice before checking his tank for particulates.
After spending a heap of money importing new replacement carbs to NZ from the USA amongst other places and neither new carb setup fixing his issues, he asked me for advice.
I suggested checking the tank and and sure enough there was small flakes (of paint I presume) blocking the fuel taps.
Sometimes the cheap solutions are the best.
BTW he experienced similar symptoms; the tank would get to a certain level and he would start getting fuel starvation / rough running / bucking issues.
good luck
[ This message was edited by: durkster on 2004-09-08 03:21 ]
durkster is offline   Reply With Quote
Old 09-08-2004   #4 (permalink)
good luck
Old 09-09-2004   #5 (permalink)
mecscc's Avatar
Interesting observation, durkster. We know that there are paint problems with the paint flaking off around the gas fill inlet. What I can't visualize is how the amount of gas in the tank makes any difference.
In any case, that well may be the problem. Wabbit, if it is, do let us know. This old dog still likes to learn new tricks.
Take care, guys,
Monte
Monte
"The Old Ohio Preacher Man"
Old 09-09-2004   #6 (permalink)
Favorite Bike: 1999 Triumph Thunderbird
Other Motorcycle: 1999 BMW R1200c
I had a 99 Adventurer that did this all the time. I found that simply cracking open the gas cap took care of it. I think they have had venting problems with these tanks.
Buck
bbuckley is offline   Reply With Quote
Old 09-10-2004   #7 (permalink)
Cafe Racin' Moderator
Favorite Bike: 1996 Thunderbird - Nessie
cafetbird's Avatar
Other Motorcycle: 1973 Triumph TR7RV
Extra Motorcycle: 1968 Bridgestone 350 GTR
Clear the vapor hole in the fuel cap.... probably has some blockage.
Scot Dail
Charlotte RAT
http://www.queensrats.cjb.net
Scot Dail, IBA #31553
Pack Member, Charlotte RAT
Old 09-11-2004   #8 (permalink)
Their are 2 petcock screens set at different heights. The lower one is for reserve. I'd concur that you have crap clogging the screens. It's a common problem and simple fix. Drain the tank, disassemble the petcock (2 screws), inspect and carefully clean the contraption. Carb cleaner works fantastic. You should separate the parts too, no need to fully disassemble, just loosen everything. I've had these symptoms too. I found some reddish crud, consistency of fine sand, probably rust.
Jerry V. - Northern NJ
Jcatbert is offline   Reply With Quote
Old 09-13-2004   #9 (permalink)
If you do pull the tank , please also give it a good visual internal inspection with a flashlight.
If you see any corrosion / flaking you may want to use something like POR-15 to re-etch and then reseal the tank surface.
Old 09-15-2004   #10 (permalink)
robbie's Avatar
Hi
have a look here
fuel tap
Robbie and 'Mohan' the original Silver Tiger
TIGER 955i 2003
My Photos
robbie is offline   Reply With Quote
T-Bird running rough at specific low engine speeds Two wheel tiger Hinckley Classic Triples 17 02-20-2008 09:03 AM
Rough Running at low throttle opening Brit_Keith Modifications & Workshop Talk 6 07-18-2006 11:28 AM
rough running low speed angusmcd Trophy 6 05-10-2006 12:14 PM
Legend rough running at low revs Hinckley Classic Triples 1 04-21-2005 11:50 AM
Rough Low Speed Running Beemie Hinckley Classic Triples 18 06-06-2004 12:39 AM
