I'm newbie in this forum, and since it's quite time consuming to check all the quotes, can someone tell me, which tankbags fit TB / TBS? Magnetic / straps?
Thanks!
Mine doesn't either. As you can see from my side shot above the top of the tank is at about the same height as the top of the fly screen. When I expand the tank bag it goes up a bit higher but I can't recall right now if it blocks the instruments.
I have a Chase Harper. Mine has a removable map pocket (most are). Magnetic. With a magnetic I would strongly urge that you use the leash strap that mounts over/around your risers/handlebar. Mine is a 'multi-mount', meaning you can go with straps and/or magnetic. I find that it takes the air off of the lower chest (usually a plus).
My only other suggestion is that you insure that when full (bring along a couple of sweaters and small towels) to verify that the bag can't get too wide and cause the starter/horn buttons to get pushed when you turn your handle bars full lock. The only time anyone will ever hear your stock horn and look.
