Trident-Exhausts.comMotorcycle.comAdvanstarMotorcycleShows
ShopTriumph.com
Old 01-24-2007   #1 (permalink)
Favorite Bike: 95 TBIRD
patrol21's Avatar
Just a quick question. My tank on my Tbird is without the rubber pads. Anyone have a set sitting or know where they can find them?
The worst day riding beats the best day at work....no exceptions.
patrol21 is offline   Reply With Quote
Old 01-24-2007   #2 (permalink)
Favorite Bike: Well, Duh!
MickMaguire's Avatar
You can buy them from Triumph, not horribly expensive $45-$55 dependant upon the style you choose...
<BR>
<BR>take a look here
[ This message was edited by: MickMaguire on 2007-01-24 11:00 ]
Mick...
Old 01-24-2007   #3 (permalink)
KD5QOQ's Avatar
How do they install? Self adhesive?
Jimbo
Kroger Plus Member
99 Adventurer
05YZ450F
89 CR500
81CR250
KD5QOQ is offline   Reply With Quote
Old 01-24-2007   #4 (permalink)
<BR>On 2007-01-24 11:51, KD5QOQ wrote:
<BR>How do they install? Self adhesive?
<BR>
<BR>yes - you should clean and de-wax the paint first (with some alcohol) but then you just peel off the backing and stick them in place. Warming the tank and pads a little with a hairdyer can help too.
[ This message was edited by: MickMaguire on 2007-01-24 11:55 ]
Mick...
Old 01-24-2007   #5 (permalink)
patrol21's Avatar
Thank Mick......cheers
Old 01-26-2007   #6 (permalink)
thaw
I have a pair off my '98 TBS, perfect shape, $40!
Old 01-26-2007   #7 (permalink)
You can use ones that have already been used but to stop them peeling you really need to remove the factory adhesive and use a contact cement to fix them on. This can be a little messy and it will mean that removing them will most likely require a repaint, but it cant be done and works well.
[ This message was edited by: MickMaguire on 2007-01-26 09:59 ]
Mick...
Old 01-27-2007   #8 (permalink)
Favorite Bike: 2000 Adventurer
Woody1911a1's Avatar
Other Motorcycle: 67 T100C
Extra Motorcycle: Buell Blast ;-)
thaw said I have a pair off my '98 TBS, perfect shape, $40!
they're only 45 -55 per pair new , not 45-55 each i believe , the package i saw on the rack at my triumph dealer today i'm pretty sure had a pair in it .
Woody1911a1 is online now   Reply With Quote
Tank Pads Gob-ny-geay Twins Technical Talk 2 06-19-2007 01:49 PM
Tank Pads Function or Looks? Caferider19 Twins Technical Talk 24 03-19-2007 04:58 PM
Tank pads premier Speed Triple Forum 8 07-23-2006 09:56 PM
Motografix Tank pads??? lofathd Speed Triple Forum 1 03-31-2005 07:50 PM
Tank Traction Pads? kuhlka Speed Triple Forum 5 03-09-2005 06:02 PM
