BikeBanditMotorcycle.comTrident-Exhausts.comAdvanstarMotorcycleShows
BikeBandit
Old 08-16-2004   #1 (permalink)
Favorite Bike: 99 Legend
Other Motorcycle: 2004 RS
When I push the starter button on my 99 Legend I get nada, zipo. The starter makes no sound whatsoever, not even a click. The battery has been taken out and replaced with one that starts my other bike (same battery size). All fuses are OK. It started great last time I rode it 2 weeks ago. Could it be the starter/kill switch button failed? Any suggestions before I take it to my dealer? Thanks! :???:
geebee is offline   Reply With Quote
Old 08-16-2004   #2 (permalink)
mecscc's Avatar
Well, start with the obvious: the problem is electrical.
Check first to see it the headlight comes on, or the turn signals work, etc. to determine if it is a full power down or just in the starter circuit.
Then, be sure that the simplist things are done: That the kick stand is up, otherwise it won't start; that the kill switch is in the "on" position; that you haven't turned the key past the "on" position, the bike is in neutral, etc.
If no lights come on then you know it is the entire circuit and not a starter switch or kill switch problem. So you will need to check the battery connections carefully, if you know that the battery is sound. Could be you left something on after you last rode it and the battery is drained. (You say that the other battery starts your other bike, will the battery in the Legend start the other bike? If so, then the battery is not likely the problem.
And also check the main fuse, it may be blown. I know you checked it, but check it again. Sometimes they look pretty good but have a fine short in them. If you have another one, try it. If it is deferctive you can replace it, just remember that something caused it to blow and until that is found it could do it again.
If the lights come on and you suspect the kill switch or starter button are not making contact, first spray some electrical contact cleaner into the switch housing, loosen it first so you can get at the components. This is not likely, unless you have recently run the bike in a downpour or just washed it.
From there, you would have to start checking out the starter leads, and the starter relay.
Finally, you would have to check the main circuit of the wiring harness for shorts, corrosion, etc.
Now, keep in mind that this is likely something simple, maybe even embarrassingly obvious, so take it slow and do everything carefully.
The most likely culprits (even though you must doubt it at this point) are a dead battery or a blown fuse. If the lights come on brightly, etc. then those are NOT the problem. Just don't go tearing into stuff that isn't broke until you are really sure that you have eliminated the obvious.
Then, if you don't have a friend who is good at electrical problem ****hing, I guess you will have to get it to a shop and have them track it down. Only problem with that is that you have to pay for the time they spend trying to isolate the problem.
Let us know how it comes out.
Monte
Monte
"The Old Ohio Preacher Man"
Old 08-16-2004   #3 (permalink)
Do you know if your starter has been rather sluggish for a while?... Like you had a weak battery? Mine had these symptoms until, like yours, it just wouldn't turn over.
My problem ended up being the starter brushes..
Dave Arnold
'04 Rocket III
'01 Trophy 1200 (wife's ride)
La Vernia, TX
tbsrider2000 is offline   Reply With Quote
Old 08-17-2004   #4 (permalink)
Thanks a lot for all the suggestions. I am quite sure now the battery and fuses are not the source of the problem. Head lights, turn signals, horn work fine and the suspect battery easily started my other bike. I have also sprayed the starter/kill switch button with the electrical cleaner as suggested without any success. Prior to this event the starter did not show any signs of a problem. It turned over like new. I am not a skilled technician but I do have a volt meter. How do I check to see if I am getting current to the starter? Thanks for your help.
Old 08-17-2004   #5 (permalink)
Hold the red lead from your volt meter on the cable where it connects to the starter (move the rubber boot out of the way). Hold the black lead to a good ground. Set the meter to DC voltage. While you're holding the leads and watching the meter have a friend hit the starter button with the ignition on. If you see 12 volts you'll know that the starter is getting juice. If not, the problem is upstream which would be the starter relay. That's the round thing that the big starter cable goes to.
Try that and get back to us.
j98
j98sprint is offline   Reply With Quote
Old 08-17-2004   #6 (permalink)
Favorite Bike: '04 Thunderbird
Other Motorcycle: 1998 Honda CBR1100XX
What J98 said triggered a memory - one of the spade connectors to the soleniod was dislodged when I removed the gas tank of my TBird.
Since you've been in and removed the battery - the solenoid lives in the same general area - just check to see all the leads are still firmly attached.
Jodel is offline   Reply With Quote
Old 08-17-2004   #7 (permalink)
Favorite Bike: 2003 Speed Triple
Other Motorcycle: '95 Tbird/ '92 Trophy
Extra Motorcycle: '72 Tiger/'96 Tbird (WIP)
Try playing with the clutch while starting. There's a switch behind the clutch lever that may have a bad contact preventing the starter to turn. I sometimes have that problem on my Tbird.
Osara is offline   Reply With Quote
Old 08-17-2004   #8 (permalink)
Favorite Bike: '98 Thunderbird Sport - Buford
denny's Avatar
Other Motorcycle: '96 Thunderbird - Bessie
Extra Motorcycle: Anything that runs
On the sidestand saftey switch there is a little rubber boot. Sometimes that little rubber boot gets disloged and interferes with the proper operation of that switch. Well anyway that has happened to my TBS a couple of times. The first time that happened I was puzzled for several hours.
cheers,
Denny
Cheers,Denny
denny is online now   Reply With Quote
Old 08-18-2004   #9 (permalink)
Well guys, I've ran all the suggested checks and found that I am not getting any current to the starter. So it's got to a problem upstream from there but at least now I am better informed about the problem and can provide my findings to the service dealer. Thanks for everyone's valued suggestions and support.
Old 08-18-2004   #10 (permalink)
mecscc's Avatar
Let us know what it finally turns out to be. Could help someone else later on that encounters the same frustrations.
I can think of no bike problem more frustrating that an electrical short. Well, maybe an oil leak you can't figure out the source of; or maybe a stutter in the carbs that were just cleaned, synched,.................forget it.
Monte :-D
Monte
Right turn vs Left turn Kramocker Twins Technical Talk 14 11-18-2007 11:21 AM
I Can't Turn cap-10ken Modifications & Workshop Talk 3 08-03-2007 03:38 AM
Okay, who's going to turn in their S3? R100Pilot Speed Triple Forum 25 02-20-2007 11:40 AM
won't turn over....? npicklo Speed Triple Forum 31 01-29-2007 07:18 PM
Does S4 "turn in" DaveC Triumph SuperSports 11 04-06-2005 12:16 PM
