FINALLY managed to start my bike today, I found out how to by pass the Datatool 3 alarm! Here's how it's done in case you find yourself in a similar situation. Unplug the 2 terminals (one 8 pin and one 6 pin) then make a connection between pins 1 and 2, and 5 and 6 on the 6 pin terminal. That's all there is to it. The easiest way to make those connections is with a paper clip. Cut it so that you are left with a u shape and push it into the terminals, easy.
