I wouldn't wire them directly to the headlight curcuit.
Use the relay, and wire that to a 'switched ignition' circuit, eg: Ignition power.
This will enable the extra lights to turn on/off with the ignition, but be on with both high and low beams.
The only lighting circuit that I would suggest connecting the relay to would be the instrument lights.
The reason for this is:
If you take relay power from the low beams, when you switch to high beam the relay will switch off and so no driving lights...and vice versa.
If you take relay power from the parking light circuit, the driving lamps will be on when you switch to 'Park'
Take power for the extra lights directly from the battery to the relay contact terminal and from the relay to the driving lights.
Make sure that the driving lamps have a good ground connection or run an ground wire back to the frame ground point.
[ This message was edited by: Wombat on 2006-11-27 14:27 ]
Bob
Click to see My Photo Album
Age is of no importance, unless you are a cheese.
