could the brake light switch be causing the fuse to blow? the left bulb seems brighter than the right till i hit the front brake then it is just as bright. if the rear switch is stuck on it could cause too much draw as i'm riding. do the front and rear brake switches work the bulbs individually?
The brake light bulbs are wired in parallel to the front and rear switches so both switches should have the same effect.
If one bulb seems brighter with the rear brake switch then it probably means that the switch is bad (resistive) and one bulb just lights up with less voltage than the other.
If the bike is miswired in the way I suspect, then it's kind of difficult to determine how much current goes to which fuse.
The way a properly sized fuse works is that it's in a constant state of near failure -- always on the edge of blowing out -- so it doesn't take much to pop it.
If the bike has been working fine for years and has suddenly developed this problem, then you've got an intermittant short somewhere.
Jim
