BikeBandit
Old 07-15-2004   #1 (permalink)
I finally got around to troubleshooting my faulty cooling fan on my 95 t-bird and narrowed it down to the sensor. My question is where is a good online parts store for this bike or is it a better bet to go to the dealership which is very far away? My second question involves previous posts regarding a faulty ground in the headlight assembly that effected the overheat light. When my bike overheated the indicator came on but blinked along with the turn signal. I immediately shut the bike off before I could mess with the turn signal so I do not know if it is designed to blink or if this indicates the faulty ground that was previously spoken of? Any help would be appreciated.
rodmo1 is offline   Reply With Quote
Old 07-15-2004   #2 (permalink)
I had the exact same symptom on my 03 TB--temp light came on and pulsated with the turn signals--the dealer said it was a known ground fault covered by a Triumph service bulletin.
Steve
My Bike Pix Here
Classic03 is offline   Reply With Quote
Old 07-16-2004   #3 (permalink)
EdC
When you do buy your coolant sensor I'd like to know what Triumph charges for it . Let us know how you make out.
Ed
EdC is offline   Reply With Quote
Old 07-27-2004   #4 (permalink)
I bought one today for my 02 Thunderbird. $45 I thought it was a little expensive but what are you going to do?
coolant temp sensor spdfreak T3 Sport / Touring Forum 3 08-26-2007 03:47 PM
coolant temp sensor tiger-rover Tiger Chat 13 07-15-2006 02:20 PM
Flushing 01 coolant, no manual? coolant bubbles after use! speedtripleride Speed Triple Forum 1 05-21-2006 11:53 AM
Coolant Temperature Sensor Will Triumph SuperSports 1 11-12-2005 11:42 AM
Coolant temp sensor TbirdTuck Hinckley Classic Triples 2 07-04-2005 09:42 PM
