Brian...
Your friend confirmed what I was trying to say - perhaps my explanation was a bit too terse.
There is always a little bit of air in the reservoirs, and the only concern would be that, when you turned them upside down, some of that air would get into the master cylinder and line. But if the brake and clutch action seem the same, it's likely that scenario did not happen.
Additionally, the gaskets are not designed to be leakproof when fluid is permanently pushing against them (as when the reservoirs are overfilled or upside down). Also, when some fluid gets past the gasket, it can pull more fluid through, due to capillary action.
So that was why I suggested removing the covers and wiping clean the gaskets and surfaces. Removing the covers is a normal operation, as this is how you fill the reservoirs, and will not compromise the system.
Anyway, it sounds like you won't need to bleed the systems. From personal experience I can tell you that the front brake is a tedious and frustrating affair!
[ This message was edited by: parrycm on 2004-07-18 11:30 ]
Chris
"Panniers can never hold everything you want, but they CAN hold everything you need."
