» Log in
User Name Not a member yet?
Register Now!
Old 07-13-2004
when i was changing my oil awhile back i noticed a allen type bolt on the bottom of the sump is this another drain plug or just a bolt ataching to something inside ? :???:
Old 07-13-2004
Favorite Bike: 95 TB & 07 Tiger ABS
You are talking about the horizontal allen bolt, which is right next to the oil filter housing? As opposed to the larger vertically mounted allen bolt which is a little further away and which is the sump drain plug?
I have the Triumph Service Manual and it looks like it shows up in an oil circuit diagram with a torque rating of 36NM, but no explanation of what it does. Typical!
Certainly, when it comes to oil changes, the service manual only requires you to use the one sump drain plug as described above.
Chris
"Panniers can never hold everything you want, but they CAN hold everything you need."
Old 07-14-2004
glgavin's Avatar
Well, the thought is that may of the extra plugs on the sump pans are for the oil coolers on the other T3 models. What we don't know is if you connect a cooler up if oil will actually pass through.
Anybody out there try it?
:-g
Gary
98 Thunderbird Sport
www.ThunderbirdSportRiders.Net
00 Tiger
07 Mini Cooper S
85 Ron Cooper (Bicycle)
Oahu, Hawaii
Old 07-15-2004
idahotb's Avatar
Favorite Bike: 1998 Thubderbird Sport
Other Motorcycle: 1996 Sprint
Extra Motorcycle: 1997 T595 Daytona
There are two, and only one will get all of the oil out of the sump. See Rick's write up at:
Webbikeworld
He explains it way better than I can. However, don't go by the description of the bolt in the hole, because my TBS has two hex bolts and no allens.
Speed is good. It is way better to be shot out of a cannon, than squeezed out of a tube. That is why God made motorcyles.
My album
Old 07-16-2004
Wombat's Avatar
Favorite Bike: '04 Thunderbird Sport
Other Motorcycle: I wish!
And mine has only one hex bolt...the drain plug.
As Gary stated the others are for oil cooler lines when the sumps are used with other models.
The sump on my TBS has the castings for the holes but they have not been drilled.
Bob
Click to see My Photo Album
Age is of no importance, unless you are a cheese.
oil light after oil drain and refill 82triumph750 Classic, Vintage & Veteran 4 02-02-2008 12:47 AM
Thanks guys. Now How do I Drain Some Oil? meistro Twins Technical Talk 11 10-09-2006 07:19 PM
Magnetic oil drain plugs sharpshooter Triumph Twins HangOut 2 05-04-2006 03:24 AM
oil drain plug jeffro232 Speed Triple Forum 5 07-08-2005 10:05 AM
Coolant drain plugs kelticwolv Sprint Forum 1 03-19-2005 12:16 AM
