bigvinny,
Thanks for this response. You didn't mention the coils, so I'll take that as a good sign...
If I could find a set of little used Keihin CVKs for a couple hundred bucks, I'd buy them! I think the problem isn't helped by peeling paint in the tank and resulting crud that makes it through the filters and into the carbs. At least, that's what happened last year - discovered this when I left the petcock open while parked in the garage and found a huge puddle of gas on the floor
If I have to keep fixing these carbs, I'm going to trade it off for something a lot more reliable. Hate to do it, but this can't be what Triumph had in mind for a modern classic, can it?!
