Motorcycle.comBikeBanditAdvanstarMotorcycleShows
Old 07-11-2004   #1 (permalink)
A friend at work was not looking behind him very well when he backed his SUV into my parked Legend.
All the damaged parts look easy to replace,, except the rear fender.
Parts ordered (and paid for by the SUV guy).
Anyone have any experience and/or tips or replacing the rear fender?
Tom
trumpy is offline   Reply With Quote
Old 07-11-2004   #2 (permalink)
Favorite Bike: '04 Thunderbird
Other Motorcycle: 1998 Honda CBR1100XX
Don't sweat it Tom, it's an easy enough job. I have a TBird, but the process should be exactly the same. I had to mess around with the fender when I swapped over the rear sub-frame on my bike.
There are four Torx head screws which hold the fender to the top of the frame (under the seat). Depending on the model you have, the captive nuts will either be attached to the frame or to the fender itself. I think the later models have them attached to the fender.
Older models also have another two Torx screws holding the fender to the frame. These are located towards the front end of the fender about 4" up from the swing-arm. There are also a couple of bolts holding the plastic splashguard - the bit between the edge of the fender and swing-arm. If your replacement fender comes 'bare' i.e. without the plastic section, you'll need to drill out the rivets which connect the plastic splashguard to the old fender. From memory, I think the rivets are about 6mm, so you'll need a pop rivet gun.
The only other things which hold the fender on are the two Allen headed bolts on the chrome/alloy indicator mounting brackets.
Last thing you need to do is disconnect the wiring for the indicators, rear light and licence plate light. Just unbolt the items and feed the wires through the appropriate points in the new fender.
If this all sounds like a lot of work, it isn't - you'll find it is quite straightforward.
BTW: What labour rate are you charging the guy with the SUV? :razz:
Jodel is offline   Reply With Quote
Old 07-12-2004   #3 (permalink)
Thanks for the info,
I'm pretty sure the fender comes bare, but it is painted.
Sounds like it a pretty straight forward project with no hidden demons :-)
Local shop wants $400. to do everything. Not charging the SUV guy, I think her learned his lesson. I've known for a few years and he's an allright guy.
Ride safe
Tom
bike knocked over at the beach,,again! Crogers Speed Triple Forum 14 10-10-2007 02:52 PM
bike knocked over at the beach Crogers Speed Triple Forum 14 08-19-2007 05:56 PM
Bike Got Knocked over. BlackThrux Club Cafe 2 08-06-2007 07:50 PM
Opinions. Some one knocked over my Thrux TonyThruxton Club Cafe 17 07-19-2006 04:58 AM
Knocked Out 200+ Miles Over Weekend... MiamiDave The Rocket Science Forum 0 07-26-2005 07:44 AM
