Another dumb question - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismHonda PowersportsSportbikeTrackGearMotorcycle.com
Old 09-02-2006, 09:55 AM   #1 (permalink)
Im almost embarrased to ask, but after having collected my TBS today :-D , I find I cant remove the seat.
Before anyone asks, I have inserted and turned the key (in the side panel). Im daft, but not that daft.
I can get the seat releases and it moves about, but I cant seem to get it off. Is their some sneaky mechanism underneath that I have to play with.
Which way does it come off. I assume that the rear must lift first?
I am a noob :hammer: , I know, but can anyone please let me know what I am doing wrong.
Regards
Dave
Alpha is offline   Reply With Quote
Old 09-02-2006, 10:11 AM   #2 (permalink)
Favourite Bike: '98 Thunderbird Sport
denny's Avatar
Other Motorcycle: '06 Husqvarna TE 610
Extra Motorcycle: '95 TBird - Project
Yep it's tricky. Once the latch is released, slide it back a bit and then it will lift upward.
Cheers,Denny
denny is offline   Reply With Quote
Old 09-02-2006, 10:19 AM   #3 (permalink)
jimmyj900's Avatar
When you eventually get the seat off, take a look at where the lock mounts to the airbox.
It's pretty common for the box to crack and break in that area so it might need replacement or repair. If that happens the lock will shift and not give enough 'pull' on the cable.
A friend had a problem on her bike in that the screws had pulled loose. I fixed it with a couple of LARGE sheet metal screws (#10 or #12 and about 2" long) driven through the airbox. If you do this, don't drill the box first. Let the plastic spread around the screws and they'll hold better.
Jim
Old 09-03-2006, 06:31 AM   #4 (permalink)
NOT a dumb question- I had to give my '04 seat a pretty good yank to the rear. It doesn't exactly jump back on either! I tried tweaking the brackets a little (04TBS) might have helped- a little.
[edit] just saw you have a 99- I think they are hinged- "ignore the man behind the screen" now I'M embarassed
[ This message was edited by: rickj on 2006-09-03 04:33 ]
2004 Thunderbird Sport. Solo seat, cowl, TOR's
rickj is offline   Reply With Quote
Old 09-03-2006, 07:57 AM   #5 (permalink)
thanks guys, got it off. all it needed was a good tug. Havent tried to refit yet, but where does the toolkit live?
I dont think it has one, but I can exactly see where it would go either
Thanks
Dave
Old 09-03-2006, 02:53 PM   #6 (permalink)
denny's Avatar
I believe the toolkit was an option. On the bottom of the seat mine has a small spot that holds a few necessary tools. Previous Owner had the deluxe tool kit included with mine.
rickj, I believe the seat attachment is the same for all TBS.
Cheers,Denny
Old 09-03-2006, 04:52 PM   #7 (permalink)
Administrator
Favourite Bike: '04 Thunderbird Sport
Wombat's Avatar
Other Motorcycle: I wish!
None of the Hinkley Classics have hinged seats as did the earlier Meriden models.
I believe some of the TBS seats are key operated and some are bolt on.
Bob
Click to see My Photo Album
Age is of no importance, unless you are a cheese.
Wombat is offline   Reply With Quote
Old 09-03-2006, 09:54 PM   #8 (permalink)
denny's Avatar
Does your have a bolt on seat?
the '04 is the only year I have not seen up close, all the others have the locking seat.
Cheers,Denny
Old 09-03-2006, 10:36 PM   #9 (permalink)
Administrator
Wombat's Avatar
Yes it does. I stand corrected.
Must be the NON TBS models that have the bolt on seat.
Bob
Old 09-04-2006, 04:02 AM   #10 (permalink)
Denny, really?
My understanding was that all the post-'99 TBSes had a bolt-on seat, hence the various accessory seats being either '98/99 or '01+.
[ This message was edited by: geoelectric on 2006-09-04 02:02 ]
geoelectric is offline   Reply With Quote
yet another dumb question Syynful Twins Technical Talk 16 09-01-2007 05:24 PM
Really dumb question stu Sprint Forum 17 08-02-2007 12:03 PM
Dumb question..... Doc007 Speed Triple Forum 17 03-17-2007 04:56 AM
Dumb question Euro Speed Triple Forum 1 11-30-2006 07:20 PM
Dumb Question? welshrob Sprint Forum 4 11-17-2005 05:54 AM
