08-30-2006, 03:01 PM
One of my silencers is rattling, the bracket that is fixed to the silencer by 2 allen bolts is loose, I've several read posts on here that people have had trouble with the captive nuts coming loose when you try to tighten the bolts, any tips before I start? Thought of spraying loads of WD40 aroung them & leaving that to loosen them? Can the nut be replaced if the come loose?
cheers, Neil.
08-30-2006, 03:11 PM
If they are like mine you can take off the foot peg and then remove the unit from the header.
Don't know if that helps any. Good luck.
_
(_)=='(_) "..Get your motor ruuunin'..."
08-30-2006, 03:32 PM
SuperStock Favourite Bike: 2003 Trophy 1200
Posts: 239 Other Motorcycle: 2001 Legend TT
My dealer says to heat the bolts which will loosen the thread sealant. The bolt should be easy to back out without breaking the nut loose from inside the silencer. Just a thought. Hope this helps. I haven't tried it yet.
Flybiker
08-30-2006, 11:09 PM
Formula Extreme Favourite Bike: 1995 Thunderbird
Flybiker
Same advice from my local dealer.
Haven't tried it myself but it makes sense, Triumph do love the thread sealant.
Stan
08-31-2006, 08:22 AM
Site Supporter Pole Position Favourite Bike: Well, Duh!
Posts: 3,650 Other Motorcycle: Can't afford two! Extra Motorcycle: Three would be insane
cheers, Neil.
heat is your best bet, wd 40 wont do much. If the nut comes loose you will have problems - its a rivnut type of affair that is fitted into the silencer. If it breaks away from the silencer itself it just spins and there is no easy way to hold it short of drilling a small strategic hole right through the bracket and silencer and into the nut into which you can inset a steel pin. this only works sometimes.
My guess is you may be lucky and be able to nip up the bolts - just dont try to undo them first.
Has your bike got the stock mufflers ot the Triumph off-roads?
Mick...
Just remember; an awful lot of the free advice you will get on forums is worth exactly what you paid for it. There will always be somebody trying to convince you to do something really stupid, just because they did it or want to do it.
08-31-2006, 01:52 PM
the silencers ae stock, not sure I'd like to apply heat tho, although its probably the best way to do it, I'll try & tighten them when I'm in the mood!!!!
08-31-2006, 03:50 PM
Site Supporter Moto Grand Prix Favourite Bike: Mutato -- 2K Adventurer
...not sure I'd like to apply heat tho, although its probably the best way to do it, I'll try & tighten them when I'm in the mood!!!!
You only need enough heat to soften the threadlock compound -- just too hot to touch and not enough to discolor or the metal.
Apply the heat slowly so it has time to conduct through the bolts to the threads.
Jim
08-31-2006, 07:11 PM
would norma running temperature be sufficient? like work on it when the bike is hot, albeit carefully
escape reality at any cost, i say
09-05-2006, 02:13 PM
Hi Lancashirelad,
I have had this problem myself. The problem is caused to some extent by the bolts being too long and poking into the exhaust gases and getting carboned up. This makes them very tight when you come to undo them. I loosened mine a couple of turns, sprayed WD40 and tightened them up again gently. Repeat as necessary till you can get them all the way out. This should work ok if they are already loose.
I agree that the Loctite type stuff they use doesn't help but take it gently and they should come out ok.
If they don't and you do end up with a spinning riv nut you will have to grind the head off the bolt. Once you have the bracket off the riv nut can be fixed by using a pillar drill with a small drill bit to drill through the silencer into the riv nut then inserting a pin covered in araldite. Once the glue is set grind the pin down flush. Then you can use either a pair of mole grips to get the shank of the bolt out or hacksaw a slot in it and use a screwdriver.
This has worked very successfully for me.
"If it ain't broke, don't fix it"
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
stock silencer
triumphtimes |
Daytona Deliberations |
2 |
10-23-2007 10:58 PM |
silencer ID
OUTLAWD |
Sprint Forum |
1 |
05-22-2007 07:18 PM |
Silencer on 99 tiger
toowright |
Tiger Mods & Bolt-Ons (archive) |
6 |
04-15-2007 06:50 PM |
silencer vs. silencer
JDW |
Hinckley Classic Triples |
1 |
02-24-2006 08:45 PM |
Silencer to 900i ?
Polartiger |
3 |
06-03-2005 02:34 PM |
