Site Supporter Pole Position Favourite Bike: Well, Duh!
Posts: 3,650 Other Motorcycle: Can't afford two! Extra Motorcycle: Three would be insane
use the drain screws (bottom of each carb float bowl) to get the old stuff out of the carbs. Pull the plugs and give them a clean. Put a new battery in then try again. If that doesnt cure it you will most likely be into cleaning the carbs as previously mentioned.
Mick...
Just remember; an awful lot of the free advice you will get on forums is worth exactly what you paid for it. There will always be somebody trying to convince you to do something really stupid, just because they did it or want to do it.
