What rear disc did you get? and from where?
Are the front discs from the TBS or the new wheel?
Details on the spacer for the front wheel would be appreciated.
The rear disc is from Sprint Manufacturing. It is the right size for the TBS caliper but has the fitting for the wheel. I wanted to be able to go back to the spoke wheels on Sundays. (Which by now, I don't want to do)
The front discs are from the mag wheels, you need the wheel and the disc, TBS discs will not fit. Some Sprint, some older Daytona and some Trophy wheel and discs can be use.
Finally for the wheel to fit, you need to cut the spacer that is on the right side when facing the bike. I do not remember the lenght but here is a picture for you to see.
