That 29-31)) "flat spot" - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismMotorcycle.comHonda PowersportsSportbikeTrackGear
Old 08-25-2006, 05:48 AM   #1 (permalink)
at about 2900-3200+or- RPM the bike looses power and feels like the clutch is slipping (without the engine really racing. I've gone back about 22 pages in the forum (search is worthless-+ I learn a LOT) and found ONE mention of lower RPM power loss on accel in a pilot discussion on a carb jet site link (http://www.factorypro.com/Prod_Pages...900Kiehin.html)
I thought that the vibes were just a TBS thing- but is it a fixable issue? At low cruise speed and at mild acceleration it is really annoying.
is this where the 40pilot and 100 main comes in...or should come in?? other than at that RPM everything seems great-
[ This message was edited by: rickj on 2006-08-25 03:49 ]
2004 Thunderbird Sport. Solo seat, cowl, TOR's
rickj is offline   Reply With Quote
Old 08-25-2006, 08:17 AM   #2 (permalink)
Favourite Bike: Well, Duh!
MickMaguire's Avatar
its to do with the harmonic balancer and the nature of the triple. In reality the right way to ride these bikes is to keep the revs higer than you would a twin - up in the 3500 area and above.
Mick...
Just remember; an awful lot of the free advice you will get on forums is worth exactly what you paid for it. There will always be somebody trying to convince you to do something really stupid, just because they did it or want to do it.
Old 08-25-2006, 08:54 AM   #3 (permalink)
AHA- OK Thanks! I can do that! Next is TOR pipes- I'll be posting!
By the way Mick- since you are an Admin- nothing personal on the "search" issue- I'm really getting a good course in my new bike by going back through the entire forum- as long as I go back faster than the forum goes foward- I'll eventually be in the present!
Old 08-25-2006, 09:05 AM   #4 (permalink)
I never notice the flat spot because I accelerate right through it.
2000 TBS Cafe Racer :: 2000 Frankenmille
TBSstunta is offline   Reply With Quote
Old 08-25-2006, 09:15 AM   #5 (permalink)
Tre900's Avatar
I used to hit that flat spot and I would get freaked out by it. Then I found I wasn't alone. But the biggest thing that changed it was when I drilled out the baffles in my stock (cone) silencers.
As if the more air it could blow out without reisitance the smother I was climbing the power band. I made not changes to jetting although the result was the decelerating "popping" which I personally enjoy listening too.
This site rocks dude...good luck with your ride. It's all going according to plan.
_
(_)=='(_) "..Get your motor ruuunin'..."
Tre900 is offline   Reply With Quote
Old 08-25-2006, 10:25 AM   #6 (permalink)
I agree!! I would never have been able to do a search on this because I wouldn't have known the correct "lingo" to describe it. I have experienced that "flat spot" but assumed it was something I was doing wrong as a newbie rider. It really helps to learn from the pros! Someday when I have extra time, I''l follow Rick's lead and work ny way thorugh the archives!
DocG
DoctahG is offline   Reply With Quote
Old 08-25-2006, 02:48 PM   #7 (permalink)
I accellerate right through that RPM range and never ride in that range, never. I like to keep in the best accelerating gear fofr thhe conditions, never under 4k.
Cheers,
Martin
martingilly is offline   Reply With Quote
Old 08-25-2006, 04:03 PM   #8 (permalink)
Tre900's Avatar
Great point Martain.
This bike was designed to be ridden higher then 3k RPM. It feels best at the 5k range but my ear took getting use to that when I decided to drill my baffles out.
Currently I'm thinking about putting some old school shoty mufflers on to make it blast. I want to see how it sounds.
_
Old 08-25-2006, 07:23 PM   #9 (permalink)
Favourite Bike: Me Thunderbird of course
Other Motorcycle: Toyota Landcruiser
Extra Motorcycle: IT 490
A three into one exhaust system fixes it. :-D
I believe there is no such thing as accidents. When I ride I must leave enough room for others stupid mistakes, added to that is enough room to make my own.
WoodsieIII is offline   Reply With Quote
Old 08-25-2006, 10:34 PM   #10 (permalink)
The flat spot at 3000 RPM was one of the first things I asked about when I got my T-Bird. Responses included:
a) it lessens with time/engine break in
b) after a while you won't notice it
I can't say for sure if 'a' is true, but I can say that 'b' is definitely true. I don’t notice it at all now. In fact, just the other day I realized that I no longer notice it. In part I think that the bike has “trained” me to accelerate right through it.
hyzer is offline   Reply With Quote
Flat spot at around 2500 rpm thefly Sprint Forum 2 07-21-2006 08:33 PM
S4 Flat Spot Stampy Triumph SuperSports 13 07-11-2006 12:44 AM
Flat Spot Boozer Club Cafe' 3 11-22-2005 01:20 AM
Do I Have a "Flat Spot" at 4k rpm? Liontari Twins Talk 10 10-16-2005 10:33 AM
latest tune flat spot Gearloose Tiger Chat 3 05-05-2004 05:48 AM
