120# mains ! - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Old 08-24-2006, 03:32 AM   #1 (permalink)
For those considering binning the airbox :
I have been running 120# main jets in Keihin CVK carbs and freeflow air filters (with standard exhausts) for a year now and done about 1000 miles.
I live at sea level and do mixed motorway and A road riding.
The point is that the NGK Iriduim plug cores are just the right "buff" colour indicating the mixture is just right and im getting and extra 20 miles per tank before going on to reserve.
The bike runs really well with loads more power than standard. I am happy ive got this setup right for my environment !
BigVinny is offline   Reply With Quote
Old 08-24-2006, 10:11 AM   #2 (permalink)
By "free flow air filters," do you mean pods? If so, which ones are you using?
I do want to dump the stock air box!
GatorBait is offline   Reply With Quote
Old 08-24-2006, 11:53 AM   #3 (permalink)
Tre900's Avatar
Also did you change your carbs? I thought Mikuni's were on the 97's?
_
(_)=='(_) "..Get your motor ruuunin'..."
Tre900 is offline   Reply With Quote
Old 08-25-2006, 03:36 AM   #4 (permalink)
Yes - you are both correct:
The carbs were originally Mikuni's but were changed to Keihin CVK's off a 2001 TB (with added copper washers under each needle) - eBay special I left the bike standing when I worked abroad and the Mikunis corroded badly ! The Keihins are more economical.
The "free flow filters" are pods, I have got US made S&B maxi flow 2.25x3.5x2x4 125-RC-T conical
http://www.mandp.co.uk/productInfo.aspx?catRef=508134
Old 01-03-2011, 10:54 PM   #5 (permalink)
Favourite Bike: triumph legend 2000
Other Motorcycle: 02 cbr 954[honda]
Extra Motorcycle: 79 kawa kz 650
do you think this set up would work on a legend-i just cleaned the carbs and would like to do without the airbox for a while-the legend has the cvks on it alredy
irish mike is offline   Reply With Quote
120+ HP. amanger Twins Technical Talk 3 10-03-2006 11:14 PM
Jets and Mains IamNeighbordave Hinckley Classic Triples 12 06-01-2006 04:44 PM
125 mains to 130 dowop Twins Talk 0 04-09-2006 06:58 PM
Re-jetted to 115 mains...she screams! Liontari Twins Talk 13 03-04-2006 10:53 PM
NARK on 150 mains & still lean DickBender Twins Talk 10 09-24-2005 07:30 PM
