On 2004-07-08 21:55, jimmyj900 wrote:
Yup! The mixture screws are used to tweak the idle mixture at the factory and can be about anywhere. On my bike all three were in the range of 1/2 to 1 turn
Mine were at 2-1/2, 1-1/2, and 1/2... does that mean I need to tune and adjust those individually after replacing the jets, or is it better to set them all at the same level?
Where are you finding the flat spots? The torque on my Adventurer dips at around 5,000 rpm.
In 1st it dips around 5K, in 2nd around 6K, and in 3rd & 4th around 3800 - but only if I have the throttle at least 3/4 open... and if I give it more gas it powers through the lull and picks back up again as the revs go up.
plunk in a set of #145 main jets, #40 pilot jets, second notch from top on the FP needles and 1 turn on the mixture screws.
Well, I got 120s going by the 'ClassicTuning 10A' document... I'll see how it goes and report back!
I've got some dyno curves if you're interested.
Absolutely - e-mail or pm me about them if you've got the time.
Thanks Jim!
